It's been a while since I've done this, but IIRC you can use the shift tube with existing bushing if you don't have access to a shaft setup for console shift. IIRC, I took all of the column shift guts out except for shift tube, and cut off the the shift lever at the end of the tube and ground it smooth like it was never there. When the upper column (with new console shift parts) is assembled, I believe the top of the shift tube will fit into the forward-most piece of upper column that houses the key release. When the key release is pushed down, it will slightly turn the shift tube since it is attached to it.
