Re: Tired of gratuitous mockup pics yet?
[Re: SNK-EYZ]
#2590468
12/11/18 05:41 PM
12/11/18 05:41 PM
Posts: 17,912 S.E. Michigan
ZIPPY
S.E. Michigan
Hey SNK, I was looking at the curved tray.
Which tray are you using in the reproduction hemi pan? You have 4.500 stroke I presume? What's your total fill and max rpm?
Pls feel free to PM if that is preferable.
The one I am doing has 2.200 journals.
Thx, Rich
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2590515
12/11/18 06:55 PM
12/11/18 06:55 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
The curved one from 440 source will not work with the hemi,440 six pack pan.
[Re: CSK]
#2590547
12/11/18 08:08 PM
12/11/18 08:08 PM
ZIPPY
S.E. Michigan
The curved one from 440 source will not work with the hemi,440 six pack pan. Thanks, good info. Of course part of me wants to see how far off it is/whether I could work with it.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2590551
12/11/18 08:21 PM
12/11/18 08:21 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Hi Tony, taking baby steps towards a 572ci Street Hemi, eventual upgrade for the old Plymouth. More accurate to say street/strip but I will just stop there knowing you're very familiar with that whole deal (if you're not careful...next thing you know, it's a race car). Nice! No adding 509 cam and 1.8 rockers for you. Going right for the jugular with the monster hemi, I like it! Looking forward to hearing how it turns out
2 kids and a dog
[Re: ZIPPY]
#2590609
12/11/18 10:50 PM
12/11/18 10:50 PM
Posts: 31,076 Oregon
AndyF
Being cross bolted, I was thinking nobody made a girdle.
That World block doesn't need a girdle. Should be good for a couple thousand HP as is.
[Re: ZIPPY]
#2590626
12/11/18 11:25 PM
12/11/18 11:25 PM
ZIPPY
S.E. Michigan
Hey thanks. I put a production type MP tray in the mule 440 (I call it that because it's still kicking) and a milodon in the 451, but other than the deep milodon one....no extras. I might accept the tray loan even though the girdle won't be used. Will keep looking at it and develop a plan. Of course, plans are always subject to change (This started as a low compression 528).
Rich H.
Esse Quam Videri
[Re: AndyF]
#2590654
12/12/18 12:44 AM
12/12/18 12:44 AM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
I don't know if such an animal exists or not but you can get sheet metal valve covers and then weld #12 AN bungs on them for screw in breathers or use AN lines over to the core support for a Moroso 3 qt remote breather tank. AndyF, Thank you for this info, I bought the 440source welded aluminum valve covers and was wondering how exactly to handle this problem. I appreciate your knowledge and willingness to help people, i wish everyone on this board would follow your example. Sorry to the OP for the hijack
eBay-cdwmotorsports
[Re: ZIPPY]
#2590752
12/12/18 10:14 AM
12/12/18 10:14 AM
Posts: 4,319 Prospect, PA
BSB67
Prospect, PA
Hey thanks. I put a production type MP tray in the mule 440 (I call it that because it's still kicking) and a milodon in the 451, but other than the deep milodon one....no extras. I might accept the tray loan even though the girdle won't be used. Will keep looking at it and develop a plan. Of course, plans are always subject to change (This started as a low compression 528). Just let me know. Of course you don't need a girdle, just a possible means to an end. It would simply be for mock up, clearance check and maybe some ideas. I think the thickness of the girdle will give you everything your trying to accomplish. Full length tray, up tight to the rotating assy, hemi oil pan, and a nice fit in the car. Just an idea.
[Re: ZIPPY]
#2590875
12/12/18 03:33 PM
12/12/18 03:33 PM
ZIPPY
S.E. Michigan
collecting info.
Biggest detail is 1 and 3/16 stick out. I'd like to create a little bit more space between the oil and the rods sticking out. With this pan and a 6qt fill, the oil seems a little too close to the rods for a windage tray/screen to even have much effect.
confirmed, the extra deep tray is no good with that pan.
I think what I'd like more is a 1"+ deeper repro pan, like 6". I always believed that is what some of the f.a.s.t. cars appear to have...or used to...years ago I noticed some of them hang down below the K member but only slightly. Or alternately, I could shorten a 7" pan which would be easier because the sump is more squared off on most of them.
It has light interference at the pickup tube adapter, I think I can fix that. Although external is so easy with this block because of the hole in front, it's tempting to try that instead.
Will brainstorm awhile longer. I know I don't want a super stock pan with the center link poking through it.
Rich H.
Esse Quam Videri
[Re: cdwmotorsports]
#2590882
12/12/18 03:46 PM
12/12/18 03:46 PM
ZIPPY
S.E. Michigan
I don't know if such an animal exists or not but you can get sheet metal valve covers and then weld #12 AN bungs on them for screw in breathers or use AN lines over to the core support for a Moroso 3 qt remote breather tank. AndyF, Thank you for this info, I bought the 440source welded aluminum valve covers and was wondering how exactly to handle this problem. I appreciate your knowledge and willingness to help people, i wish everyone on this board would follow your example. Sorry to the OP for the hijack Hey no need to apologize, pick up any ideas you possibly can from any source, it's all good. I ran AN lines to a breather tank on my Wedge engine back in 2001 Over a period of time, though, I got tired of the clutter underhood and found it was not needed on that engine, tested up to 7000. Instead I went to OEM replacement 1970 era grommets and matching OE style breathers. Those paired up with baffles inside the valve covers is all it seems to need. But...that was a 3.75 stroke engine.....
Rich H.
Esse Quam Videri
[Re: AndyF]
#2590934
12/12/18 05:03 PM
12/12/18 05:03 PM
ZIPPY
S.E. Michigan
That World block doesn't need a girdle. Should be good for a couple thousand HP as is. LOL, yes I know. And c'mon now...you know that I know ![laugh laugh](/ubbthreads/images/graemlins/custom/laugh.gif) Just being diplomatic for a second.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2591137
12/13/18 12:36 AM
12/13/18 12:36 AM
Posts: 598 NC, USA
davenc
NC, USA
collecting info.
Zippy, I had commented on someone else's build that from their pics the windage tray itself was going to be sitting at the oil level....then some other poster pointed out that the oil will not be at that level while the motor is running. I understand deep pans help, but it is worth considering that you may have more separation than you are thinking. Dave
[Re: davenc]
#2591150
12/13/18 01:12 AM
12/13/18 01:12 AM
BSB67
Prospect, PA
collecting info.
Zippy, I had commented on someone else's build that from their pics the windage tray itself was going to be sitting at the oil level....then some other poster pointed out that the oil will not be at that level while the motor is running. I understand deep pans help, but it is worth considering that you may have more separation than you are thinking. Dave FWIW, I like to consider that too (i.e. the level will be lower when the motor is running), and that it is not sitting level either. I figure that if the oil is at the crank at the back of the motor when stationary and not running, and if the tray is up close to the crank, it'll all be good. No proof though. I will say that with full time unrestricted oiling to the valve gear, loose bearing clearances and 0W-30W oil, I've never had a problem with oil pressure up to 6800 rpm.
