pressure testing a heater core #2767854
04/24/20 02:13 PM
04/24/20 02:13 PM
md
mopars4ever Offline OP
md
How much pressure should I use to test a heater core? It didn`t leak when removed but I wanted to test it before putting it back in. I would have just bought a new one but it isn`t available.
Re: pressure testing a heater core [Re: mopars4ever] #2767857
04/24/20 02:22 PM
04/24/20 02:22 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
no more than about 20 psi
Re: pressure testing a heater core [Re: gtx6970] #2767860
04/24/20 02:28 PM
04/24/20 02:28 PM
md
md
ok, thanks
Re: pressure testing a heater core [Re: gtx6970] #2767922
04/24/20 07:55 PM
04/24/20 07:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree Typical cooling system is about 14-16 lbs so 20 should be adequate twocents beer
Re: pressure testing a heater core [Re: TJP] #2767967
04/24/20 10:19 PM
04/24/20 10:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What kind of pressure does a home water hose carry?
Re: pressure testing a heater core [Re: stumpy] #2767978
04/24/20 11:08 PM
04/24/20 11:08 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
90 pounds here.
Re: pressure testing a heater core [Re: mopars4ever] #2768016
04/25/20 06:27 AM
04/25/20 06:27 AM
Atlanta, GA, USA
Dodgevity Offline
Dodgevity  Offline
Atlanta, GA, USA
Whatever is stamped on your radiator cap.
2003 Dodge Dakota Quad Cab SLT
4.7L V8, Automatic (545RFE), RWD
310K mi
Re: pressure testing a heater core [Re: Dodgevity] #2768020
04/25/20 08:35 AM
04/25/20 08:35 AM
md
md
Quote
Re: pressure testing a heater core [Re: mopars4ever] #2768099
04/25/20 12:17 PM
04/25/20 12:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Simple question. When you open the outside faucet what kind of pressure does it put out. shruggy
Re: pressure testing a heater core [Re: John Brown] #2768102
04/25/20 12:20 PM
04/25/20 12:20 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by John Brown
90 pounds here.
Why would you do that?
System pressure might, at max, be 20 psi.
four and a half times that is unreasonable and more likely to cause a failure due to over stressing things.
Re: pressure testing a heater core [Re: stumpy] #2768105
04/25/20 12:33 PM
04/25/20 12:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Normally, 40-80 PSI
Re: pressure testing a heater core [Re: TJP] #2768299
04/25/20 11:20 PM
04/25/20 11:20 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Would be easier to test using compressed air hose. Plug 1 end of core, air into other. That way you can slowly increase air press., while core is submerged in water, and observe for bubbles. I'd go 2x times max cap rating. If replacing it is a REAL pain, as some are, test at min 2x or have recored & not woory down the road..
Re: pressure testing a heater core [Re: PhillyRag] #2768391
04/26/20 12:00 PM
04/26/20 12:00 PM
moparx Offline
moparx  Offline
where i worked and supervised on the midnight shift [42+ years] we water tested many of our products.
the lowest pressure vessels were tested to 1 1/2 times their working pressure, except for some specialty items that were tested to 2 times working pressure.
our high pressure vessels were tested at three times working pressure, except for a few items that were tested up to five times working pressure, depending on application.
these products were CLEARLY marked as to the working pressure to be NOT exceeded.
however, heater cores in my opinion, should be tested at 25# [roughly two times cap pressure of 13#]. this is on the condition the outside appearance looks VERY GOOD. if it looks bad on the outside, i consider the internal condition to be the same or worse. if that's the case, a re-core or replacement is about the only choice you have.
remember, this is only MY opinion, your results will vary.
beer
Re: pressure testing a heater core [Re: moparx] #2768438
04/26/20 02:19 PM
04/26/20 02:19 PM
md
md
Quote
That was i was going to do. I was just wondering why people were talking about the pressure of a garden hose. No replacement available that I know of. I will probably have to have a radiator shop recore it if I need to.
Re: pressure testing a heater core [Re: mopars4ever] #2768456
04/26/20 04:49 PM
04/26/20 04:49 PM
A727Tflite Offline
A727Tflite  Offline
Has anyone ever experienced a radiator cap not vent - ever?
Re: pressure testing a heater core [Re: mopars4ever] #2768460
04/26/20 04:56 PM
04/26/20 04:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Because I have used a garden hose to pressure test a heater core when I didn't have a compressor to use. I just opened the faucet a little at a time.
Re: pressure testing a heater core [Re: A727Tflite] #2768467
04/26/20 05:13 PM
04/26/20 05:13 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Once, had a chunk of loose RTV keep the thermostat from opening and it blew out a core plug.
Re: pressure testing a heater core [Re: Sniper] #2768642
04/27/20 03:48 AM
04/27/20 03:48 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
That's reason why RTV or such shouldn't be used on any fitting/gasket/bolt involving the coolant system. Ever look inside a rad core & find pcs of silicone lodged in tubes? Have also seem them lodged onto the oil pickup screens. When cured it never dissolves in antifreeze or breakdown. On brushon liquid sealants. Shame: some people believe those silicone based products are "miracle cures" .
Re: pressure testing a heater core [Re: PhillyRag] #2768658
04/27/20 08:10 AM
04/27/20 08:10 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yes, well I learned that lesson in 91, that and never use a potmetal chrome water outlet they are crap.
Re: pressure testing a heater core [Re: Sniper] #2770288
05/01/20 10:37 PM
05/01/20 10:37 PM
People's Republic of Kali
70runner Offline
70runner  Offline
As mentioned, 20-25lbs pressure should do it. If it happens to be an A/C car, then be sure to pressure test the bypass valve as well.
