Diagnostic help needed.... #2768161
04/25/20 03:37 PM
04/25/20 03:37 PM
Star Idaho
67vertman Offline OP
Star Idaho
2003 Dodge Durango, 4.7, 30,000 miles.
strange issues that keeps recurring, after you drive the vehicle and it gets warmed up.
When you shut off the engine and it sits for a little while, 3 minutes to up to 30 minutes, vehicle starts up fine, after about 10 seconds running, in drive or in park, there is no throttle response, engine has no power and motor is stumbling. I can put it in neutral and after a few seconds it runs fine, after that you can drive it with no issues, fuel mileage is good, changed spark plus and air cleaner. I cleaned the MAP sensor. There are no codes. I checked for vacuum leaks no observed. no smoke from tail pipes.
It does not happen on initial start up or when the vehicle cools down sufficiently.
Any thoughts would be greatly appreciated.
My Monster are real!
Living within your means makes life pretty easy.
Re: Diagnostic help needed.... [Re: 67vertman] #2768166
04/25/20 04:01 PM
04/25/20 04:01 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Check engine light on? Codes? If not you could have some water in the tank. When it sits the fuel an pool at the pump sump screen. When you start it the water goes directly to the injectors. I would add some good fuel additive that will remove water. Cheapest thing you can try. Years ago in a Mopar training class the instructor said you can replace every part on the car trying to fix it. He said you cant fix bad gas or poor contaminated fuel.
Re: Diagnostic help needed.... [Re: NITROUSN] #2768202
04/25/20 06:13 PM
04/25/20 06:13 PM
Star Idaho
Star Idaho
No engine lights or codes....pretty sure its not water in the tank, as it only occurs when the vehicle has been driven and shut off. Thanks though.
Re: Diagnostic help needed.... [Re: 67vertman] #2768211
04/25/20 06:25 PM
04/25/20 06:25 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Try it you have nothing to lose.
Re: Diagnostic help needed.... [Re: 67vertman] #2768259
04/25/20 08:35 PM
04/25/20 08:35 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
How old is the battery? I've seen some weird stuff happen when the battery starts going bad. I'd get it tested, after it's warmed up or just verify that the cranking voltage isn't dropping below 10.5V when it's acting up. If it's good, then move on.
Re: Diagnostic help needed.... [Re: Skeptic] #2768312
04/26/20 12:46 AM
04/26/20 12:46 AM
Star Idaho
Star Idaho
Battery is relatively new, the original owner replaced it in January of this year, but I will have it tested. I too have seen weak batteries do strange things to cars.
Re: Diagnostic help needed.... [Re: 67vertman] #2768396
04/26/20 12:11 PM
04/26/20 12:11 PM
moparx Offline
moparx  Offline
battery issues do indeed cause problems that will have you tearing your hair out ! [i have nothing on top. grin]
when you are checking your battery, look VERY CLOSELY at the cable to terminal connections for cracks and corrosion, especially on the underside.
also check the cables and connections at the under hood fuse/relay box for the same issues.
beer
Re: Diagnostic help needed.... [Re: moparx] #2768428
04/26/20 01:52 PM
04/26/20 01:52 PM
Star Idaho
Star Idaho
Sunday morning,
Checked the battery its good, pulled the cables to reset the computer. Same issue, ordered a new MAP sensor and replaced the old one, seems to idle better and so far the issue is not reoccurring, I will see how it does this next week.
Re: Diagnostic help needed.... [Re: 67vertman] #2768538
04/26/20 08:22 PM
04/26/20 08:22 PM
Guitar Jones Offline
I have heard of cleaning a MAF sensor but never a MAP sensor.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Diagnostic help needed.... [Re: Guitar Jones] #2768561
04/26/20 09:21 PM
04/26/20 09:21 PM
Star Idaho
Star Idaho
laugh2 Nice catch and I cannot blame it on fat finger typing either. whistling
Re: Diagnostic help needed.... [Re: 67vertman] #2768767
04/27/20 04:17 PM
04/27/20 04:17 PM
Star Idaho
Star Idaho
Well.....that didn't work. Same issue! whiney
Noe sure where to look next. shruggy
Re: Diagnostic help needed.... [Re: 67vertman] #2768785
04/27/20 05:27 PM
04/27/20 05:27 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
My 05 minivan does the same thing after a fuel fill-up. Especially if ambient temps are up there.
Was told there is / was a recall to replace the fuel tank , causes a vapor lock type issue
it stumbles and almost will not pull itself , till maybe 10-15 seconds after its running.
Only does it if the tank is near empty when I fill it up. . And the hotter outside temsp are, the worst it is
Re: Diagnostic help needed.... [Re: gtx6970] #2768833
04/27/20 07:25 PM
04/27/20 07:25 PM
Star Idaho
Star Idaho
hummm, mine is similar, it does it regardless of tank empty/fullness. It does feel kind of like a vapor lock, but I never heard of that issue with a fuel injected vehicle.
Thanks for the input though. the search goes on...….
Re: Diagnostic help needed.... [Re: 67vertman] #2769041
04/28/20 10:55 AM
04/28/20 10:55 AM
moparx Offline
moparx  Offline
have you tried running it with the gas cap loose or off ?
just tossing that out there. it won't cost anything to try.
beer
Re: Diagnostic help needed.... [Re: 67vertman] #2769083
04/28/20 12:32 PM
04/28/20 12:32 PM
I wonder if you guys may have a leaking purge valve allowing fuel vapors from the tank into the intake manifold. This is like flooding an engine. Or a even a fuel filled cannister. That can happen if you continually top off the tank after the pump automatically shuts off.
Re: Diagnostic help needed.... [Re: moparx] #2769206
04/28/20 05:32 PM
04/28/20 05:32 PM
Star Idaho
Star Idaho
beer
Good thought, I will give it a try, nothing to lose.
Re: Diagnostic help needed.... [Re: Guitar Jones] #2769208
04/28/20 05:35 PM
04/28/20 05:35 PM
Star Idaho
Star Idaho
I will check and see if the canister has fluid in it. I will have to check if and where a purge valve would be located on my vehicle. Thanks for the thoughts though.
Edit, yes it has one....https://www.partsgeek.com/jf6kf2w-dodge-durango-purge-valve.html?gb=pp&cid=28884375&aid=4168799306&kid=1100003048023&msclkid=f1b81eafa5081f2d5699400704dfd4ad&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping%28BSC%29&utm_term=1100003048023&utm_content=Dodge&
Re: Diagnostic help needed.... [Re: 67vertman] #2769216
04/28/20 06:38 PM
04/28/20 06:38 PM
I I know it has one. That valve should be closed when the engine is off. If it leaks or is hung open (possibly from charcoal particles when a canister comes apart from gasoline contamination) could cause the problem especially when hot.
Re: Diagnostic help needed.... [Re: Guitar Jones] #2769307
04/28/20 10:33 PM
04/28/20 10:33 PM
Star Idaho
Star Idaho
I located the valve, and pulled it off, tested it, it is working, as far as it getting power and continuity, wither or not it is leaking or hung up I cannot tell, I didn't have excess fuel in the hoses.
