spark plugs for a street 360 #2766977
04/22/20 01:40 AM
04/22/20 01:40 AM
Nampa, ID
None2Slow Offline OP
Nampa, ID
I have a 360 I need plug recommendations for. It's a 10 over 360. 10:1 compression at 2400 feet above sea level. It has 2.02/1.60 valves, .484 purple shaft with around 3.50:1 gears. I'll be running an msd ignition box and distributor. It's in a 1963 Plymouth valiant convertible with an automatic. I'm looking for recommendations for spark plugs for this car. What do you suggest, or what other info might you need? TIA.
Re: spark plugs for a street 360 [Re: None2Slow] #2766989
04/22/20 02:58 AM
04/22/20 02:58 AM
Champion RN9YC(also RC9YCwill work) or maybe, if you can find them ,one step hotter RN10YCand RC10YC or Autolite #3924 or 3925, those two Autolite plugs have the 5/8 inch hex on them but they will work fine in your motor. I can't remember the proper part # for the standard Autolite 3/4 inch reach resistor spark plugs with the standard 13/16 hex on them blush
Re: spark plugs for a street 360 [Re: None2Slow] #2766995
04/22/20 06:00 AM
04/22/20 06:00 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
What heads are on the motor? Aluminum heads usually take a different plug than a steel head. I use Autolite 3924 in my Edelbrock headed 360 and I use Autolite 65 on my stock steel headed 360.
Re: spark plugs for a street 360 [Re: None2Slow] #2767018
04/22/20 08:58 AM
04/22/20 08:58 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Great experience with the NGK BKR5E-11 or BKR6E-11 (difference being the heat range). This is a V-grove plug, I've attached the spec sheet for both the plugs as well as the NGK plug naming chart.
Oh, in my case, I went from the hotter to the colder plug as I moved from a 9.5:1 to 10.5:1 static CR on my 360 motor.
NGK - BKR5E-116953 V-Power Plug.jpgNGK - BKR6E-11 2756 V-Power Plug.jpgNGK - SparkPlug Numbering System - 1.gif
Re: spark plugs for a street 360 [Re: Cab_Burge] #2767063
04/22/20 11:39 AM
04/22/20 11:39 AM
Washington
madscientist Offline
Washington
That’s too cold for a 10:1 pump gas deal. A champion RC12YC would be the coldest for that and most likely it will need a RC14YC.
Re: spark plugs for a street 360 [Re: madscientist] #2767067
04/22/20 11:44 AM
04/22/20 11:44 AM
NGK has a good rep. I'd say stock heat range or maybe 1 colder & go from there
Re: spark plugs for a street 360 [Re: madscientist] #2767093
04/22/20 12:49 PM
04/22/20 12:49 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I agree. The 12 in a champion would be the plug for street driving .
Re: spark plugs for a street 360 [Re: mopar dave] #2767133
04/22/20 02:54 PM
04/22/20 02:54 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
A 3rd recommendation for RC12YC or equivalent other brand.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: spark plugs for a street 360 [Re: None2Slow] #2768069
04/25/20 11:02 AM
04/25/20 11:02 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
322 Champion. RN11YC4. Made to gap at .040. $1.39 at Rockauto
Re: spark plugs for a street 360 [Re: qwkmopardan] #2768155
04/25/20 03:19 PM
04/25/20 03:19 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Autolite 65 would be a stock heat range, stock configuration (13/16, extended tip, 3/4 reach) plug. Go to 64 or 63 to go colder.
This crosses to a BPR5ES NGK. Those are the only brands I would consider.
The 5/8 hex is an Autolite 3924 which goes to a BCP5ES if my memory is correct.
Champion? puke
Re: spark plugs for a street 360 [Re: None2Slow] #2768255
04/25/20 08:22 PM
04/25/20 08:22 PM
I should have ask first if this is a iron head motor or aluminum head motor?
If iron colder like I recommended originally is way safer than to hot twocents
Re: spark plugs for a street 360 [Re: Cab_Burge] #2768265
04/25/20 09:01 PM
04/25/20 09:01 PM
Nampa, ID
Nampa, ID
This is an iron head motor that has had a very light clean up in the ports. The car's going to be a nice driver.
Re: spark plugs for a street 360 [Re: None2Slow] #2768271
04/25/20 09:25 PM
04/25/20 09:25 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Iron stock. RN12YC or equivalent.
65 Formula S Cuda
Re: spark plugs for a street 360 [Re: Dave_J] #2768318
04/26/20 03:05 AM
04/26/20 03:05 AM
The 1968 to 1971 340 motors came with N9Y plugs originally work
They are not available any more I've been told so the closest one to them is the RN9YC resistor plug and then the resistor 5/8 body RC9YC in the Champion line.
I had a 8.5 to 1 compression 350 Chevy iron head motor in a 21 ft. inboard outboard ocean boat that would ping with the stock RJ12Y plugs in it and wouldn't ping with a R11Y plug in it work
He is at 10.+ to 1 compression ratio so I'm thinking a #10 or #9 champion should be just about right at his altitude twocents
Re: spark plugs for a street 360 [Re: Cab_Burge] #2768348
04/26/20 09:29 AM
04/26/20 09:29 AM
Washington
Washington
I had a 8.5 to 1 compression 350 Chevy iron head motor in a 21 ft.inboard out board ocean boat that would ping with the stock RJ12Y plugs in it and wouldn't ping with a R11Y plug in it work
H twocentse is at 10.+ to 1 compression ratio so I'm thinking a #10 or #9 champion should be just about right at his altitude
Cab, if you look up what Champion calls out in a newer catalog you’ll see it says a 12 heat range for that stuff. I can’t remember what year that changed, but IIRC there was an industry wide change in pump fuel blending (I think it was before OBDII but I wouldn’t swear to that in court), probably because of a federal regulation (wouldn’t swear to that in court either but that’s kinda what I remember) that required a heat range change.
Re: spark plugs for a street 360 [Re: madscientist] #2768352
04/26/20 09:40 AM
04/26/20 09:40 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
65 autolite, don't need to overthink this.... twocents
Re: spark plugs for a street 360 [Re: madscientist] #2768354
04/26/20 09:44 AM
04/26/20 09:44 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I think they have upped the heat range on the older engine listings because they assume they are old and need it to keep them clean from deposits of a high mileage engine.
Re: spark plugs for a street 360 [Re: B1MAXX] #2768454
04/26/20 04:33 PM
04/26/20 04:33 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
We ran 55 Autolites in our iron head race deal for years. It used to be you just had to have cold plugs. But every time I stepped it up, the thing sounded happier. So that's what it got. Went to 3924s. Same basic construction & heat with a 5/8" hex.
