71s got two female bucles on each side, one for each belt ( lap and shoulder ) which got both male ends
72/73s are the ones with the tab on male end of lap belt to engage the shoulder one which is not made to be fastened to the female buckle. And of course just one female buckle.
74s are both belts stitched into one male end... and shoulder gets a retractor hidden down the bottom rear panel, not anymore manually adjusted. The caged nut changed its location for 74s shoulder belt strap. ( around "b pillar" area instead close to the coat hook )
all roofs got the provisions on frame even if was not equipped ( if that was posible
). There is not a diff PN on Sheetmetal for a non seatbelt setup.
71/73 got same provisions... Can't recall if 74s got them too even being diff seatbelt setup.
stripped roof on pics is 71 seatbelt ( you can tell it due the male end )
applies for all mopars
