I'm not getting any spark when I start my Charger.I pulled a plug and cranked the car,but still no spark to ground.I tried a new coil with the same result.I then swapped in a new ballast resistor and still no luck.I'm using a FBO solid state voltage regulator with the Mopar Electronic distributor. Could it be the orange ECU box? If so,how do I test to see if it's bad? Everything seems to be grounded tight and secure.The car started fine until it was parked for a while in storage(the carb is getting gas,so it's not a fuel issue)Thanks for any info!
