pressure testing a heater core
#2767854
04/24/20 02:13 PM
04/24/20 02:13 PM
Posts: 13,610 md
mopars4ever
md
How much pressure should I use to test a heater core? It didn`t leak when removed but I wanted to test it before putting it back in. I would have just bought a new one but it isn`t available.
Re: pressure testing a heater core
[Re: gtx6970]
#2767860
04/24/20 02:28 PM
04/24/20 02:28 PM
Posts: 13,610 md
mopars4ever
md
[Re: mopars4ever]
#2768016
04/25/20 06:27 AM
04/25/20 06:27 AM
Posts: 39 Atlanta, GA, USA
Dodgevity
Atlanta, GA, USA
How much pressure should I use to test a heater core? It didn`t leak when removed but I wanted to test it before putting it back in. I would have just bought a new one but it isn`t available. Whatever is stamped on your radiator cap.
2003 Dodge Dakota Quad Cab SLT 4.7L V8, Automatic (545RFE), RWD 310K mi
[Re: Dodgevity]
#2768020
04/25/20 08:35 AM
04/25/20 08:35 AM
Posts: 13,610 md
mopars4ever
md
What kind of pressure does a home water hose carry? ????
[Re: John Brown]
#2768102
04/25/20 12:20 PM
04/25/20 12:20 PM
Posts: 6,317 nowhere
Sniper
nowhere
Why would you do that? System pressure might, at max, be 20 psi. four and a half times that is unreasonable and more likely to cause a failure due to over stressing things.
[Re: stumpy]
#2768105
04/25/20 12:33 PM
04/25/20 12:33 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What kind of pressure does a home water hose carry? Normally, 40-80 PSI
[Re: PhillyRag]
#2768391
04/26/20 12:00 PM
04/26/20 12:00 PM
Posts: 19,591 north of coder
moparx
where i worked and supervised on the midnight shift [42+ years] we water tested many of our products. the lowest pressure vessels were tested to 1 1/2 times their working pressure, except for some specialty items that were tested to 2 times working pressure. our high pressure vessels were tested at three times working pressure, except for a few items that were tested up to five times working pressure, depending on application. these products were CLEARLY marked as to the working pressure to be NOT exceeded. however, heater cores in my opinion, should be tested at 25# [roughly two times cap pressure of 13#]. this is on the condition the outside appearance looks VERY GOOD. if it looks bad on the outside, i consider the internal condition to be the same or worse. if that's the case, a re-core or replacement is about the only choice you have. remember, this is only MY opinion, your results will vary.
[Re: moparx]
#2768438
04/26/20 02:19 PM
04/26/20 02:19 PM
Posts: 13,610 md
mopars4ever
md
Would be easier to test using compressed air hose. Plug 1 end of core, air into other. That way you can slowly increase air press., while core is submerged in water, and observe for bubbles. I'd go 2x times max cap rating. If replacing it is a REAL pain, as some are, test at min 2x or have recored & not woory down the road..
That was i was going to do. I was just wondering why people were talking about the pressure of a garden hose. No replacement available that I know of. I will probably have to have a radiator shop recore it if I need to.
[Re: A727Tflite]
#2768467
04/26/20 05:13 PM
04/26/20 05:13 PM
Sniper
nowhere
Has anyone ever experienced a radiator cap not vent - ever? Once, had a chunk of loose RTV keep the thermostat from opening and it blew out a core plug.
[Re: Sniper]
#2768642
04/27/20 03:48 AM
04/27/20 03:48 AM
Posts: 1,757 Phila
PhillyRag
Phila
Has anyone ever experienced a radiator cap not vent - ever? Once, had a chunk of loose RTV keep the thermostat from opening and it blew out a core plug. That's reason why RTV or such shouldn't be used on any fitting/gasket/bolt involving the coolant system. Ever look inside a rad core & find pcs of silicone lodged in tubes? Have also seem them lodged onto the oil pickup screens. When cured it never dissolves in antifreeze or breakdown. On brushon liquid sealants. Shame: some people believe those silicone based products are "miracle cures" .
