Re: More good news from Indy
[Re: hudsonhornet7x]
#2769335
04/29/20 12:47 AM
04/29/20 12:47 AM
Posts: 183 Macon, Missouri
TJ2
Macon, Missouri
Would you guys feel safe having Indy build a short block now? FWIW.... The short block pictured in the screen shot of the post by Chris Wheatcraft belongs to a lifelong (40+ years) friend of mine. It's a beautiful 636 that Kenny Lazzeri put together. My buddy and 2 of his family members took off early Monday morning, and drove to the INDY compound to pick up this new aluminum 636. They spent a couple hours there visiting mainly with Charli, and some with Lazzeri. They had time to tour the 4 main buildings of the compound, and were simply amazed by the machinery and all the parts on hand. Kenny told them that he is the only one that does assembly work, such as the 636, and anything that goes out the door assembled, from short block to fully assembled engine, has been assembled only by him. The transition to and moving of the business to the Wheatcraft's home location in Ohio, is one that will not be done rapidly; but rather, it will be done in the best way possible, so as to not create disturbances in customer service, to the best of their abilities. There is an incredible amount of equipment to be moved, along with everything else that is the physical sum total of this business. Quite an undertaking, to say the least... especially while trying to continue to serve the customers. Without any other details, Russ and Fred are no longer there... period. Kenny is going to continue building the engines throughout the transition, and is expecting to continue in this capacity once everything is moved to their new facility. My friend's personal take and perspective is that Kenny seemed to be excited and happy about the new breath of fresh air that the Wheatcraft family is bringing to the business we've known for so long, as INDY Cylinder Head.
[Re: fast68plymouth]
#2769450
04/29/20 12:29 PM
04/29/20 12:29 PM
Posts: 5,164 CT
GTX MATT
CT
Are people comfortable buying blocks from them at this point? Were they already before? Can you get them?
[Re: GTX MATT]
#2769474
04/29/20 01:37 PM
04/29/20 01:37 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
The block that went to Canada was spot on with one exception, but that appears to be a clerical/transcription error on the order not a machining issued,and not a big deal honestly.
[Re: GTX MATT]
#2769478
04/29/20 01:42 PM
04/29/20 01:42 PM
TJ2
Macon, Missouri
Are people comfortable buying blocks from them at this point? Were they already before? Can you get them? A friendly 2 cents worth from the peanut gallery here... 1). Yes. 2). Yes. My buddy who picked his up this past Monday was told all of the blocks are from the new foundry, and have been for a couple months or perhaps a bit more, now. I am of the impression from my discussions with him, that this new foundry is owned by the Wheatcrafts. As I mentioned previously in my earlier post, he spoke with both Charli Wheatcraft and Kenny while he was there, so I am assuming a high degree of accuracy in the information I got from him. 3). If you are only wanting a bare block to work with, call and inquire. If you are wanting a short block (or more) built by them, it will probably be a fairly long wait. Kenny told my friend that he has 80 some more orders that followed on the list after his, yet to build. In addition to the continuous numerous orders from here in the U.S., they get orders from other countries as well. Their business has not slowed down. Quite amazing... the amount of business they are doing.
[Re: Al_Alguire]
#2833226
10/16/20 12:38 AM
10/16/20 12:38 AM
Posts: 4,072 Mo.
racerx
Mo.
Good to hear. We just got a block for a B1 project a few weeks ago. Seems much nicer than the older pieces for sure. Al what was the difference in the old blocks/new blocks? i'm doing a search on the improvements the new owners have done with these blocks.
[Re: racerx]
#2833353
10/16/20 10:26 AM
10/16/20 10:26 AM
Al_Alguire
Las Vegas
Good to hear. We just got a block for a B1 project a few weeks ago. Seems much nicer than the older pieces for sure. Al what was the difference in the old blocks/new blocks? i'm doing a search on the improvements the new owners have done with these blocks. The casting quality appears to be MUCH improved over the previous version of their blocks, material and finish. They are also working on am entirely new block architecture as well right now as well.
[Re: Al_Alguire]
#2833683
10/16/20 10:40 PM
10/16/20 10:40 PM
Posts: 4,072 Mo.
racerx
Mo.
Good to hear. We just got a block for a B1 project a few weeks ago. Seems much nicer than the older pieces for sure. Al what was the difference in the old blocks/new blocks? i'm doing a search on the improvements the new owners have done with these blocks. The casting quality appears to be MUCH improved over the previous version of their blocks, material and finish. They are also working on am entirely new block architecture as well right now as well. Thanks Al. .....kind of on the fence about purchasing a new block , thought i'll look into the indy blocks and see if there were any changes. I remember there were some oiling issues at one time with the older blocks. I'll see what the owners have to offer.
[Re: DoubleD]
#2833812
10/17/20 11:27 AM
10/17/20 11:27 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
With Russ and Fred out of the picture - I have no doubt Kenny Lazzeri is more than capable of assembling quality engines - everyone forgets he worked for and got his start with Herb McCandless - Kenny is a good guy who had horrible management and did as instructed under an environment of hostility. The sooner they can get moved the better it will be in the long run - but that is a huge financial commitment and nightmare to keep production rolling for cash flow - give it some time and watch it grow! Acually,Kenny has been at it long before he was with HM. He was building stuff up here at shop in the NYC area. I forget the name of the shop...."something" Machine. It started with an "M". Mansur......or something like that.
[Re: racerx]
#2833879
10/17/20 01:56 PM
10/17/20 01:56 PM
Posts: 4,072 Mo.
racerx
Mo.
Good to hear. We just got a block for a B1 project a few weeks ago. Seems much nicer than the older pieces for sure. Al what was the difference in the old blocks/new blocks? i'm doing a search on the improvements the new owners have done with these blocks. The casting quality appears to be MUCH improved over the previous version of their blocks, material and finish. They are also working on am entirely new block architecture as well right now as well. Thanks Al. .....kind of on the fence about purchasing a new block , thought i'll look into the indy blocks and see if there were any changes. I remember there were some oiling issues at one time with the older blocks. I'll see what the owners have to offer. One more ? for you Al.......i no you build some pretty serious engines , what kind of HP you putting though one of these block ?
[Re: racerx]
#2833917
10/17/20 03:34 PM
10/17/20 03:34 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
For me, I would love to see Indy leave engine building behind, and focus on quality parts, quality castings, upgraded castings and machining, and supply the Mopar community with excellent parts/customer service...it seems when businesses take on too much, some aspects of that business get less attention than other aspects leading to poor quality or service...or both. JMO... I'm super happy to be doing much more business with Indy since the new ownership, and you can tell the change is very POSITIVE!! Brian
Brian Hafliger
[Re: Brian Hafliger]
#2833934
10/17/20 04:33 PM
10/17/20 04:33 PM
Posts: 31,051 Oregon
AndyF
For me, I would love to see Indy leave engine building behind, and focus on quality parts, quality castings, upgraded castings and machining, and supply the Mopar community with excellent parts/customer service...it seems when businesses take on too much, some aspects of that business get less attention than other aspects leading to poor quality or service...or both. JMO... I'm super happy to be doing much more business with Indy since the new ownership, and you can tell the change is very POSITIVE!! Brian My counterpoint is that it is good for Indy to be building engines since that forces them to eat their own cooking. If their castings are bad then their own engine shop will see it first.
