Re: Another what cam is this??
[Re: hemi-itis]
#2767024
04/22/20 09:11 AM
04/22/20 09:11 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
This is pretty tempting bait for a geek like myself. Thanks alot buddy!
Left to right...I see A very wide front bearing journal, a seldom used fuel pump lobe, then a distributor drive gear. It really looks just like the handful of big block Mopar roller cams I've worked with.
But wait!
Check out the first lobe after the distributor drive gear.....could it be an exhaust lobe (as on a wedge) Or Could it be an intake lobe (as on a 426 Hemi)?
Judging from the arrangement of the lobes as shown behind the second and fourth journal, and assuming the direction of rotation is clockwise as it would normally be, I'm going to to way out on a limb and take a wild guess that the first lobe behind the distributor drive gear is an intake lobe.
If that is true and it's actually an intake lobe behind the distributor gear, and knowing what you would normally collect parts for....then I believe you're looking at a 426 hemi camshaft with the xr292r-10 grind, same grind commonly used among different brands.
Shouldn't it have a grooved 4th journal? I guess a customer could order it either way, with timed oiling or full time, although with a World block you have no choice/doesn't matter. I believe this grind and layout was used at one time on Indy crate engines and it may have been pulled from one.
Last edited by ZIPPY; 04/23/20 04:38 PM. Reason: because of a royal screw up in the post, why else??? Who would go back and edit stuff for no reason? Why are you asking? Why do you care?
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2767045
04/22/20 09:51 AM
04/22/20 09:51 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
But wait!
Another thing that is noticeable is, in front of the 4th bearing journal, the lobes for #6 have basically the same placement as the lobes for #1. This means the cam does not have 4-6 firing order swap.
Rich,if it's laying in my garage,,,,,,what did it come out of?? A HEMI of course.After I find the specs it wil be up for sale,,,,,,hint,hint
