Re: So It Begins, 1966 Dodge Charger Restification
[Re: SportFuryS/23383]
#2767619
04/23/20 08:50 PM
04/23/20 08:50 PM
Posts: 555 Berlin, CT
SportFuryS/23383
Confused
Confused
Berlin, CT
The new brake booster. Got from Advance Auto, and traded in the old core. That is all the pictures I have for now, stay tuned....
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
#2767972
04/24/20 10:44 PM
04/24/20 10:44 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
New Update-
Here are some transmission seal and transmission pictures. We took the stock torque converter out today April 24th 2020 to check the seals, and were going to replace the converter with a more snappy one to get off the line quicker. That plan unfortunately did not work out, so the stock converter is going back in. We did however learn that the transmission is a 1970 B & E body transmission, and has a 19 spline converter......
#2767974
04/24/20 10:45 PM
04/24/20 10:45 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Look at the last picture of the pan rail numbers.....
#2768055
04/25/20 10:47 AM
04/25/20 10:47 AM
SportFuryS/23383
Confused
Confused
Berlin, CT
Good morning everyone. I just figured I would post up more pictures of the engine, this time of the top half getting painted. This was done Thursday April 23rd, 2020. Below are pictures of it before the top half was painted. Note the cylinder head that we put back on in the first picture so we could paint the sides of those as well. Notice in the 4th picture that the valve covers are back on, they are there to protect the top of the inside of the cylinder heads. They will not be used on the engine though, the plan is to save them just in case we need them and put new chrome Direct Connection ones on instead. A few more to come.....
#2768056
04/25/20 10:49 AM
04/25/20 10:49 AM
SportFuryS/23383
Confused
Confused
Berlin, CT
Paint Time! A few more to come........
#2768060
04/25/20 10:51 AM
04/25/20 10:51 AM
SportFuryS/23383
Confused
Confused
Berlin, CT
Engine bolts before paint, all cleaned and ready. These were painted yesterday April 24th, 2020......
#2768061
04/25/20 10:51 AM
04/25/20 10:51 AM
SportFuryS/23383
Confused
Confused
Berlin, CT
Engine bolts after paint.......
#2768062
04/25/20 10:52 AM
04/25/20 10:52 AM
SportFuryS/23383
Confused
Confused
Berlin, CT
A few pictures of the new sway bar bushing kit. Got this the same time we got the new brake booster, forgot when it was though......
#2768068
04/25/20 11:01 AM
04/25/20 11:01 AM
SportFuryS/23383
Confused
Confused
Berlin, CT
Some final engine bay pictures before the engine goes back in. Notice the battery tray is bolted in, as well as the rest of the brake lines. So that means all the brake lines are done. One more picture after these.....
#2768070
04/25/20 11:03 AM
04/25/20 11:03 AM
SportFuryS/23383
Confused
Confused
Berlin, CT
Last picture, then onto some goodies that got delivered from Jegs.....
#2768433
04/26/20 02:05 PM
04/26/20 02:05 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
We Got Parts! Received them on April 24th, 2020. A couple more after these......
#2769158
04/28/20 03:33 PM
04/28/20 03:33 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
The Engine Is Finally Going Back In! It was done Friday April 24th, 2020. It's "funny" how it takes more time to put an engine back in a car than it is taking it out. We must of spent at least an hour getting it lined up and back in. Here are some pictures......
#2769169
04/28/20 03:52 PM
04/28/20 03:52 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Got some ambition today to clean up the old starter a little bit, or at least just the date code part. Here is a picture of the numbers that are on it. Is it a 1968 starter?......
#2769173
04/28/20 03:55 PM
04/28/20 03:55 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Got some ambition today... Are you kidding me? At the pace you are moving? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) I'd settle for 5% of your energy.
#2771390
05/05/20 11:49 AM
05/05/20 11:49 AM
SportFuryS/23383
Confused
Confused
Berlin, CT
Hi all, Sorry I have not provided an update on the Charger in a little while, it has been coming along lately and a lot of work has been done. I first want to start with the interior, the drivers seat is now out of the car and sold thanks to someone on Moparts, as I am also a member there. It was taken out of the car on Monday April 27th, 2020 and sold Tuesday April 28th, 2020. I figured I would double check the seat back to see if there was a broadcast sheet in there just in case, I unscrewed the bottom seat back screws and popped it open........Unfortinatley nothing, ![down down](/ubbthreads/images/graemlins/custom/down.gif) . I however do think I may have found something under the passenger seat though, but not sure if it is a broadcast sheet or not. More on that in a bit. Here are a few pictures of when the seat was out of the car and before the interior was vacuumed out. Pretty disgusting. The very last picture is the bottom of the seat after it was out, good thing they make new foam for these......
#2771394
05/05/20 11:58 AM
05/05/20 11:58 AM
SportFuryS/23383
Confused
Confused
Berlin, CT
Update-
April 30th, 2020. The new brake booster was painted, 2 and final coats of paint were on this when I took these pictures.
