Re: 69 fender tag decode help
[Re: LimeliteAero]
#2766440
04/20/20 06:57 PM
04/20/20 06:57 PM
Posts: 2,253 New York
rarefish
New York
The AL4 code I would assume is a factory typo error. Maybe it should have been A14 which was the Spring Special Pkg. with the vinyl top.
I guess it is A14 after I looked a little closer.
[Re: rarefish]
#2766566
04/21/20 05:28 AM
04/21/20 05:28 AM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Code Description E63 383-4 Barrel D32 H-D A-727 TorqueFlite Trans / Some Years A-998 RM23 R = Plymouth Road Runner M = Medium 23 = 2 Door Hardtop H96 H = 383 330HP OR 335HP 1-4BBL 8 CYL 9 = 1969 6 = Newark, DE, USA 272336 Sequence Number '272336' R6 Paint Code: Unknown At This Time R6 Trim Grade/Style/Color R = R Class 6 = Vinyl Bucket Seats = Unknown HX2 Upper Door Frame: Unknown At This Time X9 287377 Order Number: 287377 A14 Roof Type OR Color: Plymouth Spring Special w/o Vinyl Roof A31 3.91:High Performance Axle Package M21 Roof Drip Rail Moldings M31 Belt Molding 69-70 R11 Music Master Radio AM V1X Full Vinyl Top - Black 521 Unknown At This Time V21 Performance Hood Treatment V68 Delete Stripes 26 26 in. Radiator END End of Codes
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: Savoy1964]
#2766571
04/21/20 06:39 AM
04/21/20 06:39 AM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
Code Description E63 383-4 Barrel D32 H-D A-727 TorqueFlite Trans / Some Years A-998 RM23 R = Plymouth Road Runner M = Medium 23 = 2 Door Hardtop H96 H = 383 330HP OR 335HP 1-4BBL 8 CYL 9 = 1969 6 = Newark, DE, USA 272336 Sequence Number '272336' R6 Paint Code: Unknown At This Time R6 Trim Grade/Style/Color R = R Class 6 = Vinyl Bucket Seats = Unknown HX2 Upper Door Frame: Unknown At This Time X9 287377 Order Number: 287377 A14 Roof Type OR Color: Plymouth Spring Special w/o Vinyl Roof A31 3.91:High Performance Axle Package M21 Roof Drip Rail Moldings M31 Belt Molding 69-70 R11 Music Master Radio AM V1X Full Vinyl Top - Black 521 Unknown At This Time V21 Performance Hood Treatment V68 Delete Stripes 26 26 in. Radiator END End of Codes I believe the 6= Newark, DE is actually a G for the St Louis, MO plant, 521 is scheduled build date of May 31, 1969 & R6 paint is red.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
[Re: LimeliteAero]
#2766681
04/21/20 12:13 PM
04/21/20 12:13 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Thanks Savoy and Tim! sounds like a pretty cool car right! The second R6 has me a little confused though. As mentioned I agree the 6 is a G. The R6's are lower body red and the other R6 is upper body red IE: no V-top
[Re: RJS]
#2766696
04/21/20 12:32 PM
04/21/20 12:32 PM
TimS
Walton, Indiana
Also H2X is the Interior code. On this Roadrunner H=High trim level, 2= vinyl bench seat, X=black.
This isn't a bucket seat car, originally.
[Re: RJS]
#2766744
04/21/20 02:10 PM
04/21/20 02:10 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
Thanks Savoy and Tim! sounds like a pretty cool car right! The second R6 has me a little confused though. As mentioned I agree the 6 is a G. The R6's are lower body red and the other R6 is upper body red IE: no V-top Thanks Ron, so the spring time vinyl top code over rides the second R6?
[Re: TimS]
#2766745
04/21/20 02:11 PM
04/21/20 02:11 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
Thats one of the codes that stumbled me! even the column was swapped then which isnt usually the case as the car is currently a console bucket configuration.
