69 fender tag decode help #2766333
04/20/20 02:44 PM
04/20/20 02:44 PM
SE Pa.
LimeliteAero Offline OP
SE Pa.
Could someone decode this for me. Ive got some of it but some is confusing to me.
Re: 69 fender tag decode help [Re: LimeliteAero] #2766440
04/20/20 06:57 PM
04/20/20 06:57 PM
New York
rarefish Offline
rarefish  Offline
New York
The AL4 code I would assume is a factory typo error. Maybe it should have been A14 which was the Spring Special Pkg. with the vinyl top.
I guess it is A14 after I looked a little closer.
Re: 69 fender tag decode help [Re: rarefish] #2766566
04/21/20 05:28 AM
04/21/20 05:28 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Code Description
E63 383-4 Barrel
D32 H-D A-727 TorqueFlite Trans / Some Years A-998
RM23
R = Plymouth Road Runner
M = Medium
23 = 2 Door Hardtop
H96
H = 383 330HP OR 335HP 1-4BBL 8 CYL
9 = 1969
6 = Newark, DE, USA
272336 Sequence Number '272336'
R6
Paint Code: Unknown At This Time
R6
Trim Grade/Style/Color
R = R Class
6 = Vinyl Bucket Seats
= Unknown
HX2 Upper Door Frame: Unknown At This Time
X9
287377 Order Number: 287377
A14 Roof Type OR Color: Plymouth Spring Special w/o Vinyl Roof
A31 3.91:High Performance Axle Package
M21 Roof Drip Rail Moldings
M31 Belt Molding 69-70
R11 Music Master Radio AM
V1X Full Vinyl Top - Black
521 Unknown At This Time
V21 Performance Hood Treatment
V68 Delete Stripes
26 26 in. Radiator
END End of Codes
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: 69 fender tag decode help [Re: Savoy1964] #2766571
04/21/20 06:39 AM
04/21/20 06:39 AM
Walton, Indiana
TimS Offline
TimS  Offline
Walton, Indiana
Originally Posted by Savoy1964
Code Description
E63 383-4 Barrel
RM23
M = Medium
23 = 2 Door Hardtop
H96
9 = 1969
6 = Newark, DE, USA
R6
R6
R = R Class
= Unknown
X9
V68 Delete Stripes
26 26 in. Radiator
END End of Codes
I believe the 6= Newark, DE is actually a G for the St Louis, MO plant,
521 is scheduled build date of May 31, 1969 & R6 paint is red.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: 69 fender tag decode help [Re: TimS] #2766648
04/21/20 10:49 AM
04/21/20 10:49 AM
SE Pa.
SE Pa.
Thanks Savoy and Tim! sounds like a pretty cool car right!
The second R6 has me a little confused though. As mentioned I agree the 6 is a G.
Re: 69 fender tag decode help [Re: LimeliteAero] #2766681
04/21/20 12:13 PM
04/21/20 12:13 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
The R6's are lower body red and the other R6 is upper body red IE: no V-top
Re: 69 fender tag decode help [Re: RJS] #2766696
04/21/20 12:32 PM
04/21/20 12:32 PM
Walton, Indiana
TimS Offline
TimS  Offline
Walton, Indiana
Also H2X is the Interior code. On this Roadrunner H=High trim level, 2= vinyl bench seat, X=black.
This isn't a bucket seat car, originally.
Re: 69 fender tag decode help [Re: RJS] #2766744
04/21/20 02:10 PM
04/21/20 02:10 PM
SE Pa.
SE Pa.
Thanks Ron, so the spring time vinyl top code over rides the second R6?
Re: 69 fender tag decode help [Re: TimS] #2766745
04/21/20 02:11 PM
04/21/20 02:11 PM
SE Pa.
SE Pa.
Thats one of the codes that stumbled me! even the column was swapped then which isnt usually the case as the car is currently a console bucket configuration.
