Rear main seal leak #276620
04/04/09 11:05 AM
04/04/09 11:05 AM
Slidell, la.
1BAD383 Offline OP
08 SRT Challenger
1BAD383  Offline OP
08 SRT Challenger
Slidell, la.
The rear engine seal on my 71 Super Bee is leaking. Is their any oil additive that I can add to the engine oil that would stop the leak. I don't want to pull the engine, because it is running fine.
Re: Rear main seal leak [Re: 1BAD383] #276621
04/04/09 11:40 AM
04/04/09 11:40 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
They can be changed in the car. It's not the most
pleasant experience but it can be done.
Re: Rear main seal leak [Re: 1BAD383] #276622
04/04/09 12:06 PM
04/04/09 12:06 PM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
Re: Rear main seal leak [Re: ngpSatellite] #276623
04/04/09 12:33 PM
04/04/09 12:33 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Carquest has a good seal additive that does work in moderate cases. It is a bandaide but not a repair. I do not remember off hand the name but have used it and it worked. I am sure NAPA would have the same product. If you have a knowledgeable counter person they should know what it is.
Re: Rear main seal leak [Re: 1BAD383] #276624
04/04/09 06:22 PM
04/04/09 06:22 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
You may want to try this first. Get some brake fluid and put a cap full in your oil. The brake fluid will cause the rubber seal to swell. It takes driving 2 to 3 hundred miles before the leak stops. Had a leaky tranny dip stick seal, put a little brake fluid on and it caused the 0-ring to seal. stopped leaking.
