Re: new distributor
[Re: MR_P_BODY]
#2761699
04/08/20 08:43 PM
04/08/20 08:43 PM
Posts: 4,457 Washington
madscientist
Washington
What are your pulley diameters..measure them ^^^^^^^^^^^^^^^^^^^^^^^^^ THIS^^^^^^^^^^^^^^^^^^ The pump MUST turn faster than the crank.
Re: new distributor
[Re: 8urvette]
#2761715
04/08/20 09:24 PM
04/08/20 09:24 PM
madscientist
Washington
okay just measured the crank pulley its OD is 6.5" the water pump pulley OD 6.7"
uhhhh, that can't be good. That’s bad. Very bad.
Re: new distributor
[Re: Cab_Burge]
#2762024
04/09/20 07:26 PM
04/09/20 07:26 PM
Posts: 782 wine country
8urvette
wine country
Swapped the leaky pan gasket for a new leaky pan gasket ![mad mad](/ubbthreads/images/graemlins/custom/mad.gif) Took it for a test drive. Trans works great, shifts well. Holds gears downshifts when asked 2. All good. Still runs at 210*+ Also my exhaust seems to be insanely hot. It's not glowing despite how the picture looks, but it sure has rainbowed... this is back about 2 feet from the rear axle. I'm really starting to think something is seriously wrong with this motor.
Re: new distributor
[Re: 8urvette]
#2762092
04/09/20 09:37 PM
04/09/20 09:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You can just pull the valve cover and do it... put the wheel on but you need to find TDC... you can do that in the #1 cyl turn the crank both ways to find TDC if you know what I mean then use the rocker to find the max lift before and after(I use... .050both sided of max lift) then see what you have ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
