451 B1 nitrous cam #2765806
04/19/20 09:32 AM
04/19/20 09:32 AM
La.USA
rick4106 Offline OP
rick4106  Offline OP
La.USA
Have a 451 short block from joez. Hardblock,aluminum mains,aluminum rod, and B1 nitrous pistons. B1 originals with single 4 cast intake. Looking for cam spec recommendation.
Re: 451 B1 nitrous cam [Re: rick4106] #2765993
04/19/20 03:38 PM
04/19/20 03:38 PM
NC
440Jim Offline
440Jim  Offline
NC
What compression ratio will you end up with?
Who did the porting on the B1 original heads and/or what does the flow sheet look like?
Re: 451 B1 nitrous cam [Re: 440Jim] #2766136
04/19/20 10:18 PM
04/19/20 10:18 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
best thing you can do is call Scott Brown, he can get you a good nitrous cam and he is familiar with this combination. Your heads will need chamber softening or your going to need some serious retard timing wise.
....BAD A$$ STREET CAR.....
Re: 451 B1 nitrous cam [Re: n20mstr] #2766146
04/19/20 10:44 PM
04/19/20 10:44 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Tom Hemphill has a lot of both B1 and nitrous experience. He is located in Pa.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 451 B1 nitrous cam [Re: rick4106] #2766171
04/20/20 01:23 AM
04/20/20 01:23 AM
This sounds like a stock block build, is it? If so which block and year casting is it?
Did he (the engine builder) or you have the block sonic tested before starting?
I sincerely hope so, especially if it is a 400 block.
If it is a 440 block be very careful on how much power you make with it twocents
IHThs
Re: 451 B1 nitrous cam [Re: Cab_Burge] #2766185
04/20/20 05:23 AM
04/20/20 05:23 AM
La.USA
rick4106 Offline OP
rick4106  Offline OP
La.USA
630 casting 400 block. Compression should end up around 11:1. No flow sheets yet on heads. Heads were down by Muscle Motors for a Top Dragster . Motor made a touch over 1000 with a 604. Softening chamber?
Re: 451 B1 nitrous cam [Re: rick4106] #2766247
04/20/20 11:24 AM
04/20/20 11:24 AM
N
n20mstr Offline
n20mstr  Offline
N
OVER 1000 with a stock block? be very careful with nitrous on it. Sounds a little optimistic to me, but im sure its possible just don't see how its going to live long that's all. IF you putting a healthy dose of nitrous on it, Single digit timing is where id start, but you didn't give any nitrous PPH numbers so im only speculating here.
Google Chamber Softening and im sure you will see whats involved. Basically it lays the chamber back and slows the flame front, allow more timing to be run or at least not be so timing sensitive for heads with small chambers like a B1
Re: 451 B1 nitrous cam [Re: 440Jim] #2766249
04/20/20 11:26 AM
04/20/20 11:26 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Assuming this is race-only?
The cam selection must include: how much nitrous?'
Chamber softening: convert all sharp edges into blended radius, dress down anything right at the spark plug, exhaust valve seat, and the dome's exhaust valve pocket.
If you have a chamber and/or piston photo, I may be able to identify obvious troublesome areas.
Boffin Emeritus
Re: 451 B1 nitrous cam [Re: polyspheric] #2766285
04/20/20 12:26 PM
04/20/20 12:26 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
From what I have studied on the subject of chamber softening the general idea is to eliminate or relieve the quench pad and lay the chamber walls way back along with what was said above. It's something I want to try on the new combo here as well. Sure wish we could score an affordable cast iron low deck block! I have the same "630 casting" blues over here. Hopefully yours lived an easy life in a Cordoba or something because it's going to be hell from here on lol.
Re: 451 B1 nitrous cam [Re: rick4106] #2766290
04/20/20 12:38 PM
04/20/20 12:38 PM
It is very easy to make over a 1000 HP N/A with a decent set of B1 with less than 450 C.I. with a tunnel ram and two good big carbs up Those combinations like to make HP revved above 7000 up to 8600 RPM or so work Think twice, build once twocents
That combination won't live in a stock block though whiney shruggy
Re: 451 B1 nitrous cam [Re: Cab_Burge] #2766353
04/20/20 03:22 PM
04/20/20 03:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I agree, the smallest error with nitrous (too soon, too much, too lean, too hot, too advanced) is fatal at that power level.
Boffin Emeritus
Re: 451 B1 nitrous cam [Re: polyspheric] #2766365
04/20/20 03:34 PM
04/20/20 03:34 PM
La.USA
rick4106 Offline OP
rick4106  Offline OP
La.USA
Heads came off a 604ci that made a touch over a 1000. Ill get some pics
