Re: Big block stroker, please post your low rpm torque! [Re: Cab_Burge] #2766854
04/21/20 06:59 PM
04/21/20 06:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
I found some of the original sheets from my first dyno session on the 511 C.I. 400 stroker motor with the 906 iron heads and some from my current 400 block 517.2 C.I. E85 bracket motor.
The pump gas motor made 550Ft lbs. at 3000 RPM, peak torque at 4200,4300 and 4500 RPM of 633 Ft lbs testing air cleaners, peak HP was at 5500 and 5600 RPM with 605 HP.
My current bracket motor has a set of ported 440-1 heads with a set of Jesel 1.55 paired shaft rockers, Ultra dyne solid roller and a Indy 400-3 Intake with a A.J. Casselini converted Holley Dominator Compression ratio varies from 14.72 to 15.03 to 1.
I had issues with the Mopar bonze oil pump drive having the gear on crooked on the shaft or something causing it to make the distributor housing wobble making the timing goofy shock We set the timing and made three pulls before I saw the problem with the distributor moving realcrazy
That motor made 591.5 Ft lbs at 3900 RPM with416. HP, it made peak torque on that pull at 5800 RPM making 673.7 Ft. Lbs., peak 767. HP was at 6200 RPM , torque was still 649.7 FT lbs. at that RPM.
IHTHs.
Re: Big block stroker, please post your low rpm torque! [Re: gregsdart] #2767069
04/22/20 11:51 AM
04/22/20 11:51 AM
Idaho
LaRoy Engines Offline
Idaho
4.15 stroke 496.
Edelbrock RPM heads ported to 309 cfm @ .600" lift
10.3:1 compression
612 lb-ft @ 3,300 rpm
640 lb-ft @ 4,000 rpm
640 hp @ 5,900 rpm
Re: Big block stroker, please post your low rpm torque! [Re: LaRoy Engines] #2767171
04/22/20 05:33 PM
04/22/20 05:33 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Not trying to jump ship here but what about 4.15 x 4.31 Hemi with stock heads? I see from some of the combos above, those heads flow more than stock Hemi heads so would those engines be compatible in torque numbers? Impressive engine numbers for all posted so far.
Re: Big block stroker, please post your low rpm torque! [Re: cudaman1969] #2767215
04/22/20 08:20 PM
04/22/20 08:20 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
440 base 496 ci
10.7;to 1
edelbrock 300 cfm
flat tappet cam
654 hp @ 5600 rpm
653 Tq @4400
3600 lbs Dart runs 10.4 in the 1/4 mile
Scot Brown built buyracingparts.com
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Big block stroker, please post your low rpm torque! [Re: caper] #2767349
04/23/20 10:12 AM
04/23/20 10:12 AM
The Great White North
RAMM Offline
RAMM  Offline
That's more like it. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Big block stroker, please post your low rpm torque! [Re: cudaman1969] #2767580
04/23/20 06:53 PM
04/23/20 06:53 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Had a couple of those now......Turn up the volume, you will love the sound of this little 484 Hemi...
https://www.youtube.com/watch?v=mrm62S2Fmow
Re: Big block stroker, please post your low rpm torque! [Re: rb446] #2767694
04/23/20 11:48 PM
04/23/20 11:48 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted by rb446
Originally Posted by 383man
My 493 with a 440Source 4.15 stroker kit
Indy EZ heads
10.6 comp
Good quench as I drive and race it on 92 pump
Never dyno'd but has run a best of 10.76 @ 125 in my 63 Sport Fury that's 3700 lbs without me. Ron
616fwhp up
Thanks as I figured its only about 600 at the flywheel and maybe 525 at the wheels on the calculator I used. But I would rather your figures be right. up Ron
Re: Big block stroker, please post your low rpm torque! [Re: CSK] #2767698
04/23/20 11:50 PM
04/23/20 11:50 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted by csk
No dyno#s
512 ci, 4100lb 68 Charger , street car trim 3.54 gear 11.04 @ 123 so far.
You have a very good running combo at that weight. up Ron
Re: Big block stroker, please post your low rpm torque! [Re: 383man] #2767703
04/24/20 12:14 AM
04/24/20 12:14 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thanks Ron, your car aint no slouch , awesome car !!!
Re: Big block stroker, please post your low rpm torque! [Re: CSK] #2767713
04/24/20 12:34 AM
04/24/20 12:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
[quote=csk]Thanks Ron, your car aint no slouch , awesome car !!! [/quote
Thank you. wave Ron
Re: Big block stroker, please post your low rpm torque! [Re: cudaman1969] #2767737
04/24/20 06:04 AM
04/24/20 06:04 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
My HEMI is 4.36 x 4.5 (540 ci). Strictly a street engine on pump 93. 10.3 compression, MP aluminum heads with bowl work. Mopar “Marine” dual plane intake, 248/254 @ .050 solid roller with .580 net lift.
It made 500. Ft Lb @ 3,000 rpm, 680 ft. Lb @ 4,500 rpm and 677 HP @ 5,800
Re: Big block stroker, please post your low rpm torque! [Re: 1974 474 Duster] #2769213
04/28/20 06:33 PM
04/28/20 06:33 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
I was asked through “messenger” to post my dyno sheet. Here it is.
Re: Big block stroker, please post your low rpm torque! [Re: Hemi Allstate] #2769225
04/28/20 07:07 PM
04/28/20 07:07 PM
gregsdart Offline OP
Originally Posted by Hemi Allstate
Originally Posted by gregsdart
To learn a bit more about head choices for 493 to 540 STREET strokers, please post
1cubic inch
2head used
3Dyno torque down low, preferably from 2500 to 4000?
4work done on heads, compression ratio
I see the big inch engines posted so here is one a little smaller .
470 cu
Edelbrock RPM heads . Port matched to RPM intake some minor port work and a comp valve job. 10.72 to one good quench.
Mark
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Big block stroker, please post your low rpm torque! [Re: gregsdart] #2769479
04/29/20 01:43 PM
04/29/20 01:43 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Here's my 496" Hemi. Stage V Heads. Runs on Pump 91 non-ethanol. Around 10:1.
