Re: Belt driven oil pump
[Re: hemienvy]
#2765930
04/19/20 12:02 PM
04/19/20 12:02 PM
Posts: 3,580 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
340Cuda, yes your pictures probably would be helpful. Is there a power steering pump also ? That would be crowded. No power steering or alternator but a vacuum pump. Several are on the engine stand, prepping the engine for a trip to the dyno. One shot is of a Peterson "Wet Vac" pump that would have combined the oil and the vacuum pump. It mounted nicely on the block but hit the steering box. Let me know if I can be of any help, Bill
[Re: hemienvy]
#2766469
04/20/20 07:30 PM
04/20/20 07:30 PM
Posts: 4,649 aotearoa
rebel
aotearoa
Stanton, you can change drive pulley ratio, but one big advantage to me is no abnormal wear on cam gear and pump drive gear. what do you call abnormal wear? you have the dizzy on one end & an oil pump on the other, they kinda balance themselves out. Have never seen or heard of anyone saying their cam gear has worn away.
[Re: rebel]
#2766475
04/20/20 07:42 PM
04/20/20 07:42 PM
Posts: 9,183 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
[quote=hemienvy] Have never seen or heard of anyone saying their cam gear has worn away.
I think he's referring more to the wear of the oil pump drive gear and bushing.
[Re: Stanton]
#2766491
04/20/20 08:16 PM
04/20/20 08:16 PM
rebel
aotearoa
I think he's referring more to the wear of the oil pump drive gear and bushing. But we're in the race section here, so it's not like we're going to drive a zillion miles on these motors, race engine parts get checked at freshen up time & a new gear for the intermediate shaft has to be way cheaper than a remote pump.
[Re: hemienvy]
#2766545
04/20/20 10:38 PM
04/20/20 10:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Engine is getting a roller cam.
It can't be possible that everyone has forgotten about roller cam gear/pump drive gear failures, can it ?
Please reread my original post. How many failures have you heard about vs the number of engines that run the same set up.. I an sure way more run the set up vs what you heard about
[Re: MR_P_BODY]
#2766561
04/21/20 02:24 AM
04/21/20 02:24 AM
Posts: 6,187 Melbourne , Australia
LA360
I don't believe there is a commercially available mount bracket available, (unless Andy F lists one) it's not a particlarly common conversion. A friend of mine was talked in to it, a whole lot of expense for very little benefit really. He had an ATI dampener with a BBC front pattern, could run an off the shelf drive kit, rather than me having to machine one. I had to make the block off/inlet plate to go to the block in place of the factory oil pump. His engine is going on to a chassis car, so I can't comment on whether it will clear the K frame.
Alan Jones
[Re: hemienvy]
#2766563
04/21/20 03:18 AM
04/21/20 03:18 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
If your main reason for an external pump is gear wear, I suggest you re-read the very first reply after your bringing up the issue. Surely this can’t be the first time you’ve heard how to set up a roller cam pump drive.?.?.?.
[Re: MR_P_BODY]
#2766565
04/21/20 04:22 AM
04/21/20 04:22 AM
Posts: 784 Southington Ct.
turbobitt
Southington Ct.
As said already.. put a hard washer in there or a torrinton bearing in there Any more information or pics on this mod ? I'm interested since I seen some wear on my roller cam setup and in the process of installing a new bushing and would like to make a permanent fix. AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
