window motor servicing
#2765217
04/17/20 07:36 PM
04/17/20 07:36 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey Gang..
Just picked up an window motor for my 69 Hemi Charger 500.. Wanted to try a new one first since the old ones are, well, 50 years old... How in the heck do I take the gear and pinion off the motor head shaft? The new motor doesn't come with it...
Thanks in advance..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: window motor servicing
[Re: hemi68charger]
#2765262
04/17/20 09:15 PM
04/17/20 09:15 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
There is a snap ring on the shaft that the gear is on. If you look at the one without the gear you will see where it goes.
NS1AAR
[Re: ns1aar]
#2765377
04/18/20 09:35 AM
04/18/20 09:35 AM
hemi68charger
Houston, Tx
I 100% agree and was looking for it.. You have to get the gear out of the way first or something...
[Re: Alaskan_TA]
#2765667
04/18/20 09:41 PM
04/18/20 09:41 PM
hemi68charger
Houston, Tx
First step if it were me would be to clean the grime off so I could get a better look at it. It is clean enough to be able to see if there's any clips and/or fasteners...
[Re: gtx6970]
#2765668
04/18/20 09:42 PM
04/18/20 09:42 PM
hemi68charger
Houston, Tx
Its been years since Ive had one of these opened up. And my memory is getting foggy. But I think once the plate is removed the gear slides up and off I will try prying ever so slowly.. T
