Re: Msd grid question
[Re: sr4440]
#2764208
04/15/20 12:05 PM
04/15/20 12:05 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Of those two options I would get the racepak O2 sensor. Not sure where you plan to race but I have seen guys get tossed by tech for just having the can bus in the car. I think some tech guys think if you have the can buss you have an ARC module, which is not necessarily true. You can have it without the ARC. I think they just did not understand what they were looking for..
[Re: Z_Z]
#2764378
04/15/20 06:59 PM
04/15/20 06:59 PM
Posts: 580 Livermore, CA
Dduster
Livermore, CA
You buy this --> https://www.summitracing.com/parts/msd-7765 to integrate with Your GRID. One guy complained the MSD O2 Kit doesn't have analog output. Really?,. You ain't got time for anything more than the other car, glancing at oil pressure and water temp during a run,at least for Me. Check the data when You get back to the Trailer. GRID will display It's own O2 sensor output in the GRID datalogger files but You can also buy the Racepak Sportsman Channel Add-On and put the MSD O2 into the Racepak output as well. As They say: Information is power .
