Re: 68-70 droptops with rally dash question
[Re: LimeliteAero]
#2764230
04/15/20 01:05 PM
04/15/20 01:05 PM
Posts: 3,524 Lansing, MI
70gtx440dana
Lansing, MI
For 1970 the Top switch is mounted to underside of upper dash. To the left of the radio. See photo.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#2764260
04/15/20 02:11 PM
04/15/20 02:11 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Aren't 68 on dash down the the speedo ? ( at a side of the wiper switch )... just like those with rear deffog ( not optional on converts )
then 69/70 on the location shown at a side of the A/C- Heater controls
[Re: 70gtx440dana]
#2764280
04/15/20 03:12 PM
04/15/20 03:12 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
For 1970 the Top switch is mounted to underside of upper dash. To the left of the radio. See photo. Aahh! Thanks man! I was trying to blow up pics and they'd get blurry but it looked like something was in that area! Thank You!
[Re: NachoRT74]
#2764281
04/15/20 03:13 PM
04/15/20 03:13 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
The cars I looked at there was nothing in that area for the 68's! the other photo is great! Thanks! Ive never seen that configuration or that switch!
[Re: LimeliteAero]
#2764294
04/15/20 03:31 PM
04/15/20 03:31 PM
NachoRT74
Valencia, España
68 without rear deffog or convertible option got a blank filler there
here with rear deffog... note the filler area for the switch...
converts got the bezel with the TOP lettering
None of them... black filler
[Re: NachoRT74]
#2764297
04/15/20 03:37 PM
04/15/20 03:37 PM
NachoRT74
Valencia, España
top switch filler on left and delete filler ( blank ) on right
[Re: NachoRT74]
#2764301
04/15/20 03:41 PM
04/15/20 03:41 PM
NachoRT74
Valencia, España
BTW, the switch location difference for top and Rear deffog switch are the same as far I know for standard and rallye clusters between 68 and 69/70. Just that standard cluster are of coruse meeting with the standard cluster bezel setup
