Hints for removing antenna nut '00 Dakota... #2763081
04/12/20 03:02 PM
04/12/20 03:02 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Need to get a nut & bezel from the pullapart for the Dakota but every Dakota or Durango I tried, I could not budge the nut using needle nose pliers. Probably get one off with channel locks but tight as they seem to be I'll probably scar it up pretty bad. What the heck did they put these things on with? I'm thinking special socket and impact. shocked
Any tips or tricks? Or do I need to order one of the little universal spanner wrenches for antenna nuts? work
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Hints for removing antenna nut '00 Dakota... [Re: I_bleed_MOPAR] #2763085
04/12/20 03:10 PM
04/12/20 03:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you take the mast off to give you a straight shot at the nut with your needle nose?
Re: Hints for removing antenna nut '00 Dakota... [Re: stumpy] #2763108
04/12/20 04:03 PM
04/12/20 04:03 PM
Buford, GA
Buford, GA
Tried it both ways. Removing the mast I could turn the whole base. frown Leaving mast in and holding with wrench prevented base turning but no go. And it's not truly a straight shot as it has 3 slots. I really think if it had 4 where you could get in slots directly opposite each other it would be much easier. shruggy
Tim
'71 Charger 383/727
Re: Hints for removing antenna nut '00 Dakota... [Re: I_bleed_MOPAR] #2763141
04/12/20 05:57 PM
04/12/20 05:57 PM
Guitar Jones Offline
Did you try harsh language?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Hints for removing antenna nut '00 Dakota... [Re: Guitar Jones] #2763166
04/12/20 07:20 PM
04/12/20 07:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Channel locks and a rag.
Re: Hints for removing antenna nut '00 Dakota... [Re: Guitar Jones] #2763320
04/13/20 09:28 AM
04/13/20 09:28 AM
Buford, GA
Buford, GA
A lot of it. laugh2
Tim
'71 Charger 383/727
Re: Hints for removing antenna nut '00 Dakota... [Re: stumpy] #2763321
04/13/20 09:29 AM
04/13/20 09:29 AM
Buford, GA
Buford, GA
My thought at this point. If I scar it too bad, I'll buff it down and paint it. up
Tim
'71 Charger 383/727
Re: Hints for removing antenna nut '00 Dakota... [Re: I_bleed_MOPAR] #2763483
04/13/20 02:32 PM
04/13/20 02:32 PM
A lot of it. laugh2
Tim
Failing all else there is a punch and hammer, air chisel or even the special wrench. laugh2 Kind of a waste of money though as you'll probably never use it again. Have you tried to buy a new one?
Re: Hints for removing antenna nut '00 Dakota... [Re: Guitar Jones] #2763744
04/14/20 09:09 AM
04/14/20 09:09 AM
Buford, GA
Buford, GA
Haven't contacted a dealership about a new bezel & nut (not holding my breath on that one) but used ones are available on ebag for, oh. around $17-18 each piece. laugh Headed back to pullapart and just going to use channel locks and a rag on it.
Tim
'71 Charger 383/727
Re: Hints for removing antenna nut '00 Dakota... [Re: I_bleed_MOPAR] #2763769
04/14/20 10:32 AM
04/14/20 10:32 AM
I've seen the multiple fit wrenches on ebay for about $14. You could get one of them and then charge $10 to remove the nuts for other people. You might even get most of your money back. laugh2
Re: Hints for removing antenna nut '00 Dakota... [Re: Guitar Jones] #2763816
04/14/20 11:49 AM
04/14/20 11:49 AM
Buford, GA
Buford, GA
laugh2
Tim
'71 Charger 383/727
Re: Hints for removing antenna nut '00 Dakota... [Re: I_bleed_MOPAR] #2763947
04/14/20 05:54 PM
04/14/20 05:54 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i am a auto body tech.
those special wrenches only work sometimes. a lot of the times the part of the wrench that matches the antenna won't work because the wrench hits the fender. they also make special sockets that work just like the wrenches.
the antenna and nut are probably both seized to the antenna mast threads, bi metallic corrosion. the antenna stud is steel and the antenna and the nut are usually alloy.
i usually heat up the parts with a induction heater and everything works fine.
my suggestion is stop by a dealer body shop and bribe a tech to remove the antenna.
chances are if you live in the rust belt you will need a new antenna because you try to remove it snaps the stud off in the antenna mast.
good luck
perception is 90% of reality
Re: Hints for removing antenna nut '00 Dakota... [Re: Mr T2U] #2764227
04/15/20 12:56 PM
04/15/20 12:56 PM
Buford, GA
Buford, GA
Thanks but I just need the nut and bezel as I bought the truck stripped for paint. Nut and bezel were MIA when I started putting it back together. up
Tim
'71 Charger 383/727
