Trick Flow 270 vs Indy EZ-1 #2762567
04/11/20 06:46 AM
04/11/20 06:46 AM
Memphis, TN
MoparJason0O0 Offline OP
Memphis, TN
Which head produces more HP both straight out of the box?
Indy EZ-1 or TFS-6161T784-C01?
I know Indy’s need some work out of the box while sometimes Trick Flows are good to go. Anyone know which head produces more power?
Re: Trick Flow 270 vs Indy EZ-1 [Re: MoparJason0O0] #2762619
04/11/20 10:05 AM
04/11/20 10:05 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Don’t know but my ootb trick flow 270 heads on a 505 with a Dwayne Porter roller cam made 713 hp 709 torque. Car not done yet but will be a street/strip car.
Re: Trick Flow 270 vs Indy EZ-1 [Re: markz528] #2762638
04/11/20 11:07 AM
04/11/20 11:07 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You’re asking if the fully cnc ported head is better than an unported head?
Yes.
From a flow perspective, the “equivalent” Indy head to the TF270 is the EZ CNC295........ and that would be after the seats were recut and blended on the EZ head.
Re: Trick Flow 270 vs Indy EZ-1 [Re: MoparJason0O0] #2762667
04/11/20 12:00 PM
04/11/20 12:00 PM
AndyF Offline
AndyF  Offline
I've tested several engines with out of the box TF 270 heads. They all made excellent power, usually 700+ hp on a typical 500 inch bracket type engine. Out of the box Indy stuff usually doesn't work very well. I don't see much of it anymore since it has a fairly bad reputation so Dwayne is the guy to ask. My Indy EZ heads made great power after they were reworked a couple of times. Modern CNC ported them and then Dwayne put the finishing touches on them. So the Indy stuff can be made to work but you have to finish them since Indy doesn't.
Re: Trick Flow 270 vs Indy EZ-1 [Re: AndyF] #2762706
04/11/20 01:43 PM
04/11/20 01:43 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Indy now has new owners & from what I have heard they are great people.
Re: Trick Flow 270 vs Indy EZ-1 [Re: fast68plymouth] #2762748
04/11/20 04:12 PM
04/11/20 04:12 PM
Memphis, TN
Memphis, TN
Fastplymouth:
I appreciate your reply and others.
I was wondering which flowed more if both were straight out the box no extra porting.
Re: Trick Flow 270 vs Indy EZ-1 [Re: MoparJason0O0] #2762757
04/11/20 04:38 PM
04/11/20 04:38 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’m pretty sure that has been answered.
Quote
The EZ 295(cnc ported EZ head) outflows the EZ-1(unported head), and the TF 270 outflows the EZ 295......until the valve seats have been recut and blended in the 295.
After the EZ 295 has been tweaked, it flows basically the same as the ootb TF 270.
I haven’t had a EZ CNC 295 in the shop since the new owners have taken over, so it’s possible they are doing a little extra finish work that might make them the flow equal to the TF 270, without additional work being required.
But, the ones I’ve had here through the years needed some tweaking to be able match the TF 270 flow.
Nothing major at all...... but tweaking.
The unported EZ-1 isn’t going to match a TF 270 for flow.
