Magnum threaded fan mount extension??
#2762318
04/10/20 01:44 PM
04/10/20 01:44 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Has anyone ever seen an extension to extend the fan forward on a 5.9 or 5.2 Magnum serpentine belt set-up? I need one to make room for the belt on a belt driven supercharger set-up.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Magnum threaded fan mount extension??
[Re: jbc426]
#2762380
04/10/20 03:41 PM
04/10/20 03:41 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Maybe just me but I'd ditch the propeller and run a good dual electric and controllers. Less rotational mass too.
But to anwser, NO, I have not.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2762386
04/10/20 03:56 PM
04/10/20 03:56 PM
Posts: 1,285 okla.
sam64
okla.
If you know a good parts person they can help by looking at the dimension section for fan clutches. I had to do this for the one in my 65 Coronet with a 5.7 hemi. I had to have a shorter shaft.
[Re: jbc426]
#2762418
04/10/20 04:57 PM
04/10/20 04:57 PM
Posts: 684 Maine
jerseybud
Maine
Factory had different length fan clutchs. For example, a v6 fan had a very long threaded portion. The 92-93 magnums had a mid sized one. The 94-03s varied a little based on HD cooling or not, or at least thats been my obervation with my junkyard engines. My 92 w250 had a spacer washer behind the fan clutch as well to get an extra 3/16 inch forward. Only seen them on 92-93s though, and not all of them. Very thick metal washer - not a hardware store piece without alot of milling.
[Re: jerseybud]
#2763168
04/12/20 07:26 PM
04/12/20 07:26 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Another vote for electric fan time. Eliminate dead weight, pick up horsepower, less noise, and more room. Otherwise, you could add a short threaded section and then thread another nut on there and put it on?
Mo' Farts
Moderated by "tbagger".
[Re: jbc426]
#2764328
04/15/20 04:49 PM
04/15/20 04:49 PM
jbc426
West Coast, USA
Has anyone ever seen an extension to extend the fan forward on a 5.9 or 5.2 Magnum serpentine belt set-up? I need one to make room for the belt on a belt driven supercharger set-up. I think I found an extension, and ordered it. They use them on diesel rigs. I'll know soon enough if it fits my needs. I need just enough room to clear a 10 rib blower belt and not enough to push the fan too close to the radiator.
