Inattention to details=bad results #2762128
04/09/20 11:06 PM
04/09/20 11:06 PM
Cab_Burge Offline OP
I have been working on my S/P car this winter, I removed and replaced the Koni steel single adjustable front coil over shocks with a set of Afco double adjustable aluminum coil overs(Thanks,Al up) and I had disconnected the inlet pressure oil line from the oil pump to the remounted mounted oil filter on the front motor plate trying to get the shocks in and out easier, that didn't work. I ended up disconnecting the lower A control arms to remove and install the shocks up through center of them, that was several months ago.
I didn't hook the oil line back up then and paid for it today when I started the motor up and sprayed oil all over the engine compartment realcrazy whiney I was planning on checking and maybe changing the ignition timing if needed due to changing the distributor before changing the coil over shocks over.
Luckily I was using a remote starter switch standing beside the drivers front fender and saw the oil spray out as soon as the motor started and got it shut off within 5 seconds or so, oil all over the engine compartment rantshruggy
My message is check twice instead of not checking, especially on race cars when working on them twocents whistling
Re: Inattention to details=bad results [Re: Cab_Burge] #2762134
04/09/20 11:20 PM
04/09/20 11:20 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
How right you are...
I put a new Dr. Diff chunk in my 8-3/4 housing six or seven years ago.
Finally got the Dart on the road this December... within 5 miles, locked up the rear because I'd forgotten to put the gear oil in.
That was a $700 mistake. shock
Re: Inattention to details=bad results [Re: DrCharles] #2762145
04/10/20 12:46 AM
04/10/20 12:46 AM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
I fell for you guys, but at least it makes me fell not so stupid when that sh!!t happen to other people.
Re: Inattention to details=bad results [Re: 72sat] #2762165
04/10/20 07:57 AM
04/10/20 07:57 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Yup been there!
Had the front passenger tire off to do some work on the car late fall, put the tire back on hand tightened the lugs, spring time came, dropped it off the stands drove 1/2 a block and the flippin tire almost fell off, lost 3 lugs bent 2 of the studs in the process, lucky i had the long studs or could have been way worse, now i put a piece of caution tape on my unfinished projects to help remind me, including a start up checklist, checking the lugs and oil levels being priority.
Re: Inattention to details=bad results [Re: RATTRAP] #2762173
04/10/20 08:33 AM
04/10/20 08:33 AM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Thought it was just me......pre-lubed my new 500 stroker. I was paying attention to the oil coming up to the rockers, forgot I hadn't put on an oil filter! BIG mess!
Re: Inattention to details=bad results [Re: RATTRAP] #2762174
04/10/20 08:35 AM
04/10/20 08:35 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
This would be a good time for FREDS, angel DAMHIK
Re: Inattention to details=bad results [Re: bonefish] #2762184
04/10/20 09:15 AM
04/10/20 09:15 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I fired my car after a transmission swap and had forgot to put the oil filter back on. I knew it would take a second to get oil pressure because the filter had been off but after those seconds were up I realized what I did and shut it off, big big mess.
I would like to take this moment to say that the powder looking oil dry at wall mart works really good!
68 Barracuda Formula S 340
Re: Inattention to details=bad results [Re: Bad340fish] #2762195
04/10/20 09:33 AM
04/10/20 09:33 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
laugh2.... its a small block thing, you wouldn’t understand
I made a stud nut set up so I don’t have to remove the filter now. Got tired of the mess when the 727 from L removal became a weekly/monthly ordeal.
Re: Inattention to details=bad results [Re: Cab_Burge] #2762210
04/10/20 10:07 AM
04/10/20 10:07 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Don't fell bad. Been there done that. Its amazing how fast that oil comes out of a disconnected hose. I was just cranking it over and that sh!it came out like a bullet. Mine was an oil line to the valve covers. It sprayed over the pass fender with such speed if someone would have been standing there I think it might have hurt.
Re: Inattention to details=bad results [Re: mopar dave] #2762219
04/10/20 10:24 AM
04/10/20 10:24 AM
A727Tflite Offline
A727Tflite  Offline
Then there are guys that lose prime -
Re: Inattention to details=bad results [Re: Cab_Burge] #2762231
04/10/20 10:45 AM
04/10/20 10:45 AM
Nevada
merpar Offline
merpar  Offline
Nevada
Focus. The older we get the harder it is. I've done worser Cab just try to focus distractions lead to disaster. I just look at old age as entertaining And pray the Good Lord is looking out for ya.
Re: Inattention to details=bad results [Re: J_BODY] #2762233
04/10/20 10:48 AM
04/10/20 10:48 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Early 2000's...19 or 20 at the time....was going to a Mopar meet up with Fluffy (Mr P's silo party?) and was finishing up replacing pads on the front of the car. Was running late and decided to make the shakedown ride the trip over. First time I applied the brake I realized I installed one of the pads backwards....don't ask....drove it like that the couple miles up the road and hung out. Used first gear to slow the car down before applying brakes when I had to stop. Wonder if anyone noticed?
Re: Inattention to details=bad results [Re: MarkZ] #2762245
04/10/20 11:08 AM
04/10/20 11:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A buddy of mine that worked in the brake lab had just finished up a brake job(he was on a
road trip in Cali)... being in a hurry he backed out and went to hit the brakes.. zero brakes and he
hit a brand new big dollar Mercedes..he forgot to pump the pedal to fill the caliper..
yes there was a law suite on Chrysler... SO SH!T HAPPENS
wave
Re: Inattention to details=bad results [Re: MR_P_BODY] #2762255
04/10/20 11:24 AM
04/10/20 11:24 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Lots of brainfarts over the years .
Back in the mechanic days put a transmission in a Volare and when I let the rack down....there's the torque converter sitting on the bench.
Towed a broke down car for a friend, his wife's car."whatever we do DON'T scratch her car she'll kill me"
Not to worry I know what I'm doing.
Back the trailer up to the shop,set the brakes....car rolls off into the parking lot.
Never strapped it down, wasn't even in park....
How it made it 12 miles is a mystery...😳
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Inattention to details=bad results [Re: MarkZ] #2762394
04/10/20 04:08 PM
04/10/20 04:08 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
While we're confessing brake job errors...
I did a complete rear brake job on my old F-350 flatbed (Dana 70 axle). Spun the lug nuts down with a 3/8" impact but forgot to torque them.
You can see where this is going whistling
Drove to the sawmill 6 miles away and got 2 tons of cut ends for my wood furnace. Coming back down the 2-lane county highway at 55 mph... no warning, wobble wobble THUMP screeeeeeeeeeeech. The left rear dually wheels came off and the brake drum slid on the pavement shock
Ron White - Tire Fell Off (NSFW)
One passed me like a cartoon and went 200 yards down the road in the other lane, the other went out the rear 1/4 mile behind me. Luckily no one was on the road at the moment but me! Bent the crap out of the 1/4" C-channel bumper too.
Once I realized I could keep it straight and come to a stop, without being underneath 3 tons of truck and 2 more tons of wood, I unclenched about six inches of seat upholstery.
The studs weren't even damaged, but my brand new brake drum was sanded really flat on one side...
The guy whose house I ground to a stop in front of, phoned his brother to bring some lug nuts from HIS house. Unfortunately they were not the right size, but it was nice of them to try.
So I called 911 since there were no shoulders and I was in the road. The state trooper who came out was the same guy who'd called me a tow truck years ago when I had a flat on my pickup (and the spare was also flat). He remembered me, too. blush He actually drove me about 4 miles to O'Reilly, I bought eight new lug nuts, and he drove me back to the truck! I'm always amazed that people in rural MO will stop to help a stranger.
I put them on and drove the rest of the way home. Ordered another brake drum (Autozone lifetime warranty did not cover it, so I didn't try) and finished the job, using a torque wrench this time! Only once in nearly 40 years of wrench-turning have I done something like that.
Re: Inattention to details=bad results [Re: DrCharles] #2762494
04/10/20 09:17 PM
04/10/20 09:17 PM
I forgot to mention that one good thing that came out of this latest debacle is I found a vacuum leak from the oil dipstick tube cap(vacuum cap) being worn with several holes that I couldn't see with the hose clamp on it up It has 5+Lbs. vacuum idling now boogie grin
Re: Inattention to details=bad results [Re: Cab_Burge] #2762523
04/10/20 10:38 PM
04/10/20 10:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cab... come on... thats inch of merc... messin with ya
wave
Re: Inattention to details=bad results [Re: MR_P_BODY] #2762544
04/10/20 11:48 PM
04/10/20 11:48 PM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
My friend had a 62 Plymouth race car with a 440. I stopped by to check it out and he fired it up, I noticed something was off when I saw a stream of oil shoot up out of the engine compartment. He had a Oberg oil filter and had opened it up for cleaning. What a mess, I offered to help him clean it up but he said no. I felt bad for him.
Re: Inattention to details=bad results [Re: J_BODY] #2762589
04/11/20 08:32 AM
04/11/20 08:32 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have two other oil related messes. Forgot to hook up my oil pressure gauge after some work. Stream shoots up, hits the hood and is distributed all over my garage. The second was 20 years ago when I put the autometer gauges in my factory panel. The oil pressure gauge is right over the column and I forgot to tighten the line. After about a mile I wondered while my feet were wet.....that pair of shoes didn't make it!
Re: Inattention to details=bad results [Re: Bad340fish] #2762659
04/11/20 11:47 AM
04/11/20 11:47 AM
I have oil the ceiling and walls in my shop when the oil pressure line was left off also realcrazy whiney
Maybe it is time for me to stop working on cars and motors and not fly anymore, maybe not whistling
80 lb. of oil pressure forced out of a .125 size hole squirts a long ways shock shruggy
