Heater cable-1983 D150
#2761161
04/07/20 04:02 PM
04/07/20 04:02 PM
Posts: 3,547 stratford,ontario,canada
JD340
Need some help finding out the part number for the heater control cable on my 83 D150, mine's broken. No numbers I can find on it. Where could I look up to find a number for it so I can possibly find a replacement? Any help is appreciated!
Nothing to see here. Carry on.
Re: Heater cable-1983 D150
[Re: JD340]
#2761182
04/07/20 04:43 PM
04/07/20 04:43 PM
Guitar Jones
There are places that can make cables. I thought I had one saved in my favorites but I don't have access to my PC now. Maybe a google search?
[Re: Guitar Jones]
#2761194
04/07/20 05:21 PM
04/07/20 05:21 PM
JD340
There are places that can make cables. I thought I had one saved in my favorites but I don't have access to my PC now. Maybe a google search? That might just be an option if I cant find a replacement. My original is stamped TEFLEX CORPORATION or INCORPORATED I forgot right now. I wonder if they're still around?
[Re: JD340]
#2761241
04/07/20 07:50 PM
04/07/20 07:50 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
I bet a throttle cable off an old junk lawnmower can be cut down and used. I made a manual choke cable out of one.
Otherwise, like Jonsey says about having one made. Motorcycle shops can make one up for you.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2761299
04/07/20 10:47 PM
04/07/20 10:47 PM
Posts: 516 ND
dodgedon
ND
I may have one. How long is it?
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: JD340]
#2761565
04/08/20 04:39 PM
04/08/20 04:39 PM
Posts: 516 ND
dodgedon
ND
I have 40" from eye to eye. This one has red tabs. The other is 27" eye to eye. This one has yellow tabs.
[Re: dodgedon]
#2761940
04/09/20 02:43 PM
04/09/20 02:43 PM
JD340
I have 40" from eye to eye. This one has red tabs. The other is 27" eye to eye. This one has yellow tabs. The first one sounds like what I need! Mine also has the red tabs and measures 36" from end to end on the cable housing itself. PM me please sir!
[Re: Ramtough]
#2761942
04/09/20 02:45 PM
04/09/20 02:45 PM
JD340
Need to know what system your truck has, I may have one, Regular heat ( No vents in dash ), Bi-Level heat ( vents in dash, no A/C ), or is it an A/C truck ? If regular heat which cable, temp or blend ? Regular heat, no Bi-level, no ac, temp cable is the one I need.
[Re: JD340]
#2762095
04/09/20 09:48 PM
04/09/20 09:48 PM
Posts: 516 ND
dodgedon
ND
Yes, the jacket on the red one is 36". I will send a pm when im on the computer tonight. Its easier....
