Heater cable-1983 D150
#2761161
04/07/20 04:02 PM
04/07/20 04:02 PM
Posts: 3,546 stratford,ontario,canada
JD340
Need some help finding out the part number for the heater control cable on my 83 D150, mine's broken. No numbers I can find on it. Where could I look up to find a number for it so I can possibly find a replacement? Any help is appreciated!
Nothing to see here. Carry on.
Re: Heater cable-1983 D150
[Re: JD340]
#2761182
04/07/20 04:43 PM
04/07/20 04:43 PM
Posts: 20,600 in a cattle trailer down by th...
Guitar Jones
There are places that can make cables. I thought I had one saved in my favorites but I don't have access to my PC now. Maybe a google search?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2761194
04/07/20 05:21 PM
04/07/20 05:21 PM
JD340
There are places that can make cables. I thought I had one saved in my favorites but I don't have access to my PC now. Maybe a google search? That might just be an option if I cant find a replacement. My original is stamped TEFLEX CORPORATION or INCORPORATED I forgot right now. I wonder if they're still around?
[Re: JD340]
#2761241
04/07/20 07:50 PM
04/07/20 07:50 PM
Posts: 5,997 Salem
Grizzly
Moparts Proctologist
Salem
I bet a throttle cable off an old junk lawnmower can be cut down and used. I made a manual choke cable out of one.
Otherwise, like Jonsey says about having one made. Motorcycle shops can make one up for you.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2761299
04/07/20 10:47 PM
04/07/20 10:47 PM
Posts: 516 ND
dodgedon
ND
I may have one. How long is it?
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: JD340]
#2761565
04/08/20 04:39 PM
04/08/20 04:39 PM
Posts: 516 ND
dodgedon
ND
I have 40" from eye to eye. This one has red tabs. The other is 27" eye to eye. This one has yellow tabs.
[Re: dodgedon]
#2761940
04/09/20 02:43 PM
04/09/20 02:43 PM
JD340
I have 40" from eye to eye. This one has red tabs. The other is 27" eye to eye. This one has yellow tabs. The first one sounds like what I need! Mine also has the red tabs and measures 36" from end to end on the cable housing itself. PM me please sir!
[Re: Ramtough]
#2761942
04/09/20 02:45 PM
04/09/20 02:45 PM
JD340
Need to know what system your truck has, I may have one, Regular heat ( No vents in dash ), Bi-Level heat ( vents in dash, no A/C ), or is it an A/C truck ? If regular heat which cable, temp or blend ? Regular heat, no Bi-level, no ac, temp cable is the one I need.
[Re: JD340]
#2762095
04/09/20 09:48 PM
04/09/20 09:48 PM
Posts: 516 ND
dodgedon
ND
Yes, the jacket on the red one is 36". I will send a pm when im on the computer tonight. Its easier....
