Re: TH400 to RB in 69 b body info
[Re: TRENDZ]
#2762019
04/09/20 07:14 PM
04/09/20 07:14 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I took the last 2yrs off running it n/a to think about it so ya I gave it time. Turbo400 is a good trans. Can be built to hold a lot of power pretty inexpensively. The same could be said for a properly built torqflite. The benefits of installing a 400 into a B body, are not... for most, worth the effort. I understand being soured on parts. But It seems that maybe you would be best off to step back, take a breath, and re-evaluate your choice of trans builder. I assure you you are not making enough power to need to walk away from a TF.
[Re: 6bblFLASH]
#2762192
04/10/20 09:26 AM
04/10/20 09:26 AM
Posts: 13,187 aZLiViN
J_BODY
aZLiViN
IMO with the blower forget horsepower, worry about the torque.
....which makes me think of the 47/48 RE torqueflight based trans behind the hopped up Cummins ISB Just curious Clanton, was it repeated failure of one component? ...or a few instances of breakage. Iโd still say at the level your at our favorite dump truck trans should be able to handle the task at hand. Sounds like your next step is getting a JY core and start mocking things up. Are there adapter kits available? I know pretty much zero about this. I do find it interesting how long people have been putting glides behind Mopars and still read about parts fitment issues here and there. Hopefully youโll start a post on this endeavor, or keep adding to this one. Lord knows we need reading material these days.
[Re: Clanton]
#2762200
04/10/20 09:52 AM
04/10/20 09:52 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
So now you are broke LOL.๐ ROSSLER builds good stuff. Keep us posted on progress and results.๐๐
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#2762211
04/10/20 10:09 AM
04/10/20 10:09 AM
Clanton
northern,Ohio,USA
I am not broke but 4,700$ is a lot just for the trans.I had a goal in mind when I started this and I will keep at it as long as I can. So now you are broke LOL.๐ ROSSLER builds good stuff. Keep us posted on progress and results.๐๐
[Re: 6bblFLASH]
#2762228
04/10/20 10:36 AM
04/10/20 10:36 AM
Posts: 4,675 On the parachute mount
n20mstr
This is where MOPARTS gets tunnel vision...and why most MOPAR guys are slower than the Brand X guys....
Someone asked about fitting a T400 to a B body, hes looking for info, what needs to be done. Instead of helping him, you guys are chastising him, telling him a 727 will work, and he don't need a 400 etc etc here some facts....
THE aftermarket is geared towards....T400, not 727's COnverters, parts etc are all cheaper and more readily available for this trans, because almost everyone out there is using it. Don't let your feelings get in the way....lol
honestly, a Rossler t400 may be overkill, but guess what, it will be THE LAST TRANS HE EVER BUYS.....keep up with fluid changes and it will literally last forever. I have a Rossler T400 for over 10 years, and still going strong. I make 915 on motor and 4-500? of nitrous on top
Clanton, to put a T400 in an A body, I fabbed a crossmember between my frame connecters. On the original crossmember, the part that passes above the trans I cut that back for clearance and fabbed a 16 ga flat steel to box it back in. Depending on how much cage you have that may not be necessary. Any more questions ask, I did not do anything to the trans tunnel itself other than trim the lip where the floor and the firewall meet. Hope this helps
PS : You made a great choice for a trans/trans builder, good luck
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2762263
04/10/20 11:45 AM
04/10/20 11:45 AM
Posts: 936 Deland, Florida
biff426
Deland, Florida
Did you lower the engine in the chassis? I mocked a 400 up in my 66 Coronet with an Ultra bell and it was not going to fit without making the tunnel bigger. I couldn't lower the engine because of the oil pan and headers so I scrapped the idea and went with a 727 I just didn't want to get into that much work. I had a simialer situation with my 65 although the engine is further forward the firewall wasn;t so much the issue as the tunnel from there back. Again both were gen 3 hemi conversions and the pan and headers limited the amount I could lower the engine. Just curious what you did to get it to fit without cutting the tunnel up. Also I agree the 400 can be just as fast as a 727 expecially when you consider the gear ratio options with the 400. I had a 210 Rossler in the purple Challenger I bought from Steff that car would go crazy sometimes and that 210 Rossler really got it under control. Also for the nah sayers I tested with a 727 vs a 400 in that car..............the 400 was faster mainly because of gear ratio and the ability to control wheel speed vs the 2.47 low gear in the 727. I know the purests here will not like that but it is the truth. This is where MOPARTS gets tunnel vision...and why most MOPAR guys are slower than the Brand X guys....
[Re: biff426]
#2762267
04/10/20 12:10 PM
04/10/20 12:10 PM
n20mstr
[quote=biff426] Did you lower the engine in the chassis? I mocked a 400 up in my 66 Coronet with an Ultra bell and it was not going to fit without making the tunnel bigger. I couldn't lower the engine because of the oil pan and headers so I scrapped the idea and went with a 727 I just didn't want to get into that much work. I had a simialer situation with my 65 although the engine is further forward the firewall wasn;t so much the issue as the tunnel from there back. Again both were gen 3 hemi conversions and the pan and headers limited the amount I could lower the engine. Just curious what you did to get it to fit without cutting the tunnel up. Also I agree the 400 can be just as fast as a 727 expecially when you consider the gear ratio options with the 400. I had a 210 Rossler in the purple Challenger I bought from Steff that car would go crazy sometimes and that 210 Rossler really got it under control. Also for the nah sayers I tested with a 727 vs a 400 in that car..............the 400 was faster mainly because of gear ratio and the ability to control wheel speed vs the 2.47 low gear in the 727. I know the purests here will not like that but it is the truth.
[quote=n20mstr]
I use a motor plate, I really cant say why, but it fits my trans tunnel no problem.?? It is an A body not a B , I was surprised myself that it fit pretty well . Im computer illiterate, so if anyone wants pics โฆ..text me your cell and what you want to see, I can text pics..LOL my number is 914 417 1312
[Re: n20mstr]
#2762288
04/10/20 12:45 PM
04/10/20 12:45 PM
Clanton
northern,Ohio,USA
The th400 from the bell back is just an 8" tube so I will test fit a tube to check the depth how it fits.I have 1" all around my 727 front to back so I think I may get lucky and only have to flat the tunnel lip to the fire wall.Thank you so much for your info! This is where MOPARTS gets tunnel vision...and why most MOPAR guys are slower than the Brand X guys....
[Re: n20mstr]
#2762325
04/10/20 01:49 PM
04/10/20 01:49 PM
Posts: 9,834 MI, usa
dvw
MI, usa
I agree the Rossler is a very nice piece. I don't care if its GM or Mopar. If you were starting wth nothing and making BIG power I see the logic. What I don't understand in this case is someone gave up at 30 passes with a trans that easily would've worked. By the time this is all said and done it'll be way over $5K. Now I don't know about everybody but spending $5K+ is a pretty big bite. Especially when what you already have would've easily worked. You tell me. How many low 10 second cars kill a 727 every 30 passes? My 727 has stranded me once in 7 years (635passes). Every pass 9.2x or better@3350 or more. It was an aftermarket part design failure which was easily corrected. My trans in my sons turbo car with a 727 using a brake at 3750lbs (9's at 136 -142) has only stranded once as well in over 5 years. Easy upgrade to fix it as well. Just my 2cents Doug
[Re: Clanton]
#2762349
04/10/20 02:47 PM
04/10/20 02:47 PM
Clanton
northern,Ohio,USA
I took some measurements off my friends th400[width,length,height from pan rail] and I will compare it to my spare 727.
[Re: Clanton]
#2762352
04/10/20 02:56 PM
04/10/20 02:56 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I am getting ready to make the move to a TH400 in my Satellite.I asked in the past for a pic of the trans tunnel adjustment but never got it so if you have 1 please post it along with the trans cross member.I am going with an Utra bell because I don't want a mid plate if I can.TIA for your help! Ohhhh my God, Chevy transmissions. Whatโs next ford 9 inch rearends. We canโt even get our guys to give up 50 years old technology and update their radiator FLEX hoses and screw clamps. Lmao. Hemi guys included.
[Re: dvw]
#2762358
04/10/20 03:01 PM
04/10/20 03:01 PM
Clanton
northern,Ohio,USA
I have 2 transmissions that I went through 3 rebuilds 2 on 1 and 1 on the other.Not just 1 trans 30 runs.Maybe that is not enough for you but it was me and here we are.just an fyi! This is where MOPARTS gets tunnel vision...and why most MOPAR guys are slower than the Brand X guys....
. What I don't understand in this case is someone gave up at 30 passes with a trans that easily would've worked. Doug
[Re: X9 X3 R/T]
#2762921
04/12/20 03:56 AM
04/12/20 03:56 AM
Posts: 672 st.louis,mo.
dart games
st.louis,mo.
maybee hes like some of us that had 727 bomb go off,i still dont trust a 727 no matter who builds it
[Re: dart games]
#2762935
04/12/20 08:19 AM
04/12/20 08:19 AM
dvw
MI, usa
maybee hes like some of us that had 727 bomb go off,i still dont trust a 727 no matter who buils it Simple answer. Aluminum drum. Doug
