Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: new distributor [Re: 8urvette] #2761687
04/08/20 08:17 PM
04/08/20 08:17 PM
Go drive it now like you normally drive it to see what is does on the road now twocents scope
Re: new distributor [Re: Cab_Burge] #2761688
04/08/20 08:20 PM
04/08/20 08:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What are your pulley diameters..measure them
wave
Re: new distributor [Re: MR_P_BODY] #2761699
04/08/20 08:43 PM
04/08/20 08:43 PM
Washington
madscientist Offline
Washington
wave
^^^^^^^^^^^^^^^^^^^^^^^^^ THIS^^^^^^^^^^^^^^^^^^ The pump MUST turn faster than the crank.
Re: new distributor [Re: madscientist] #2761702
04/08/20 08:50 PM
04/08/20 08:50 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I ordered some trans fluid. And a new pan gasket, it has a slight leak. Should be here tomorrow. I'll tear drive then. I will go measured the pulleys after dinner.
Re: new distributor [Re: 8urvette] #2761710
04/08/20 09:11 PM
04/08/20 09:11 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
okay just measured the crank pulley its OD is 6.5"
the water pump pulley OD 6.7"
uhhhh, that can't be good.
Re: new distributor [Re: 8urvette] #2761715
04/08/20 09:24 PM
04/08/20 09:24 PM
Washington
Washington
That’s bad. Very bad.
Re: new distributor [Re: madscientist] #2761727
04/08/20 09:40 PM
04/08/20 09:40 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
All these aftermarket billet pullies have a larger water pump pulley than crank pulley.
What gives?? shruggy
Re: new distributor [Re: 8urvette] #2761731
04/08/20 09:45 PM
04/08/20 09:45 PM
Go drive it now up
Re: new distributor [Re: Cab_Burge] #2761733
04/08/20 09:54 PM
04/08/20 09:54 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
its 2 quarts low on tranny fluid!!!! I will drive tomorrow!
Re: new distributor [Re: 8urvette] #2761781
04/09/20 01:43 AM
04/09/20 01:43 AM
Maybe the better reply would have been ASAP blushwhistling
Re: new distributor [Re: Cab_Burge] #2762024
04/09/20 07:26 PM
04/09/20 07:26 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Swapped the leaky pan gasket for a new leaky pan gasket mad
Took it for a test drive. Trans works great, shifts well. Holds gears downshifts when asked 2. All good.
Still runs at 210*+
Also my exhaust seems to be insanely hot. It's not glowing despite how the picture looks, but it sure has rainbowed... this is back about 2 feet from the rear axle. I'm really starting to think something is seriously wrong with this motor.
Re: new distributor [Re: 8urvette] #2762036
04/09/20 08:01 PM
04/09/20 08:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your cam timing could be off.. do you have the stuff to check it
wave
Re: new distributor [Re: MR_P_BODY] #2762083
04/09/20 09:18 PM
04/09/20 09:18 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
A degree wheel? I have that, is there a less invasive way to do? Or does the timing chain have to come off?
Seems I could do based on the balancer and the micrometer thingy, with a degree wheel on the crank balancer.
Re: new distributor [Re: 8urvette] #2762092
04/09/20 09:37 PM
04/09/20 09:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can just pull the valve cover and do it... put the wheel on but you need to find TDC... you can do
that in the #1 cyl turn the crank both ways to find TDC if you know what I mean then use the rocker
to find the max lift before and after(I use... .050both sided of max lift) then see what you have
wave
Re: new distributor [Re: MR_P_BODY] #2762135
04/09/20 11:37 PM
04/09/20 11:37 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
the car has hydraulic lifters...
can i borrow one of my solid roller lifters from my race engine for this? I don't see any reason i can't, but i just wanna get a 2nd opinion.
Re: new distributor [Re: 8urvette] #2762136
04/09/20 11:39 PM
04/09/20 11:39 PM
If your using a hydraulic flat tappet cam and lifters you need to use a solid flat tappet lifter, any roller will mess the readings up on cam timing and maybe the LSA also, maybe not though on that confused
Re: new distributor [Re: Cab_Burge] #2762137
04/09/20 11:42 PM
04/09/20 11:42 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
so drop pop rocker off and support the pushrod so it moves in a straight line and set it up on the tip of the push rod then. ok.
ill fab up some silly metal bracket to hold the push rod.
Re: new distributor [Re: 8urvette] #2762138
04/09/20 11:43 PM
04/09/20 11:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes you can,,, big deal if it starts at a different point.. it just needs to repeat(not stick in the bore)
wave
Re: new distributor [Re: MR_P_BODY] #2762852
04/11/20 08:39 PM
04/11/20 08:39 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I got to check the cam timing today.
i checked it 3 separate times readjusting the dial indicator each time- just to check and see if my results were repeatable.
The cam card call for the cam to be installed at 112* intake centerline
3 times I came up with 114*
what will this make the engine do?
also here are the cam specs-
intake- exhaust
.505 .514
duration at .050
230 240
I think this cam may be a bit 2 big for this motor.
Re: new distributor [Re: 8urvette] #2762855
04/11/20 08:46 PM
04/11/20 08:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You may want to advance it a few degrees to pick up some torque
wave
