Hemi block engine mount #2760220
04/05/20 01:38 AM
04/05/20 01:38 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Take a look at this drivers side block mount pad, I think this is a KB Stage 6 block, but not sure.
How do you attach a mount to this ?
Re: Hemi block engine mount [Re: hemienvy] #2760233
04/05/20 06:35 AM
04/05/20 06:35 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It is missing the studs that the bracket goes to. Anybody have a picture?
Re: Hemi block engine mount [Re: hemienvy] #2760263
04/05/20 08:31 AM
04/05/20 08:31 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Probably a motor plate block in all past life ...
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Hemi block engine mount [Re: hemienvy] #2760266
04/05/20 08:40 AM
04/05/20 08:40 AM
NC
440Jim Offline
440Jim  Offline
NC
Interesting. The block I bought in 2014 had three mount holes to clear the double side bolts for the main caps.
These are my measurements, FWIW.
Re: Hemi block engine mount [Re: hemienvy] #2760349
04/05/20 12:01 PM
04/05/20 12:01 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Been there, done that. On mine, I just drilled and tapped the area between the 2 bolts. Attached the mount with just 2 bolts and secured the engine with a turn buckle on that side to control the stress. Worked fine for me.
Master, again and still
Re: Hemi block engine mount [Re: hemienvy] #2760492
04/05/20 07:00 PM
04/05/20 07:00 PM
AndyF Offline
AndyF  Offline
It wasn't designed for passenger car use.
Re: Hemi block engine mount [Re: AndyF] #2760494
04/05/20 07:02 PM
04/05/20 07:02 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Guess I need to figure out how to be clever.
Re: Hemi block engine mount [Re: hemienvy] #2760580
04/05/20 10:39 PM
04/05/20 10:39 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Plate works great!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi block engine mount [Re: hemienvy] #2760605
04/06/20 12:15 AM
04/06/20 12:15 AM
AndyF Offline
AndyF  Offline
I had an aluminum Hemi block sitting in my shop for a bit and the left motor mount location was moved up about an inch from stock location. I didn't notice it until I bolted on a set of casters and the one caster was up in the air. Those race blocks were made for racing and they just put stuff wherever they wanted on them. Nobody was worried about the blocks being able to bolt into a passenger car.
Re: Hemi block engine mount [Re: hemienvy] #2760632
04/06/20 08:11 AM
04/06/20 08:11 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
On my suppos-ed Stage 2 block, the passenger mount hole pattern is higher & further forward than the the driver's side. 17/32" higher, 1 3/4" further forward. I referenced my measurements off the cross-bolt holes. They appear to be located the same on factory blocks just eye-balling pictures from a google search.
I haven't mounted mine, so I can't answer your original question with experience. My own plan was to use factory style mounts and modify them as needed.
At the end of the day, its an aftermarket part. Aftermarket parts don't tend to fit perfectly. You're just going to have to mock it up.
Re: Hemi block engine mount [Re: 73DAD] #2760720
04/06/20 12:22 PM
04/06/20 12:22 PM
AndyF Offline
AndyF  Offline
Here is a picture of the block I had. I don't remember any details on the block other than the fact that the driver side mount wasn't in the stock location.
Re: Hemi block engine mount [Re: AndyF] #2760753
04/06/20 01:44 PM
04/06/20 01:44 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thanks for the photos guys.
Here is my passenger side compared to an iron block.
Re: Hemi block engine mount [Re: hemienvy] #2760756
04/06/20 01:46 PM
04/06/20 01:46 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Here is drivers side, iron block.
Re: Hemi block engine mount [Re: hemienvy] #2760759
04/06/20 01:50 PM
04/06/20 01:50 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I have not put a tape measure on mine to see how close it really is to OE stock.
I don't know why in the hell they would move the mount holes even a tiny bit, useless question to ask I know.
Re: Hemi block engine mount [Re: hemienvy] #2760760
04/06/20 01:52 PM
04/06/20 01:52 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
440Jim, your drivers side does not appear to be the same as an OE iron block.
Re: Hemi block engine mount [Re: hemienvy] #2760825
04/06/20 04:57 PM
04/06/20 04:57 PM
NC
440Jim Offline
440Jim  Offline
NC
FWIW, here is the other side.
Re: Hemi block engine mount [Re: hemienvy] #2760842
04/06/20 05:44 PM
04/06/20 05:44 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Love it when people buy race parts and then expect to use them like stock factory parts...
Re: Hemi block engine mount [Re: Dragula] #2760929
04/06/20 10:30 PM
04/06/20 10:30 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
OK I am whining, but still what they did makes little sense to me.
If they go to trouble to add stock type mounts at all, why alter them ?
Whine.
Re: Hemi block engine mount [Re: hemienvy] #2761013
04/07/20 09:03 AM
04/07/20 09:03 AM
NC
440Jim Offline
440Jim  Offline
NC
At least you can adapt (weld/fabricate) a mount to use the factory frame positions. You don't have to use a front engine plate in a street car (if you don't want to).
If the block had no place at all, you would have to use the front plate type mounting. I would like to see the manufacturer publish what they are providing for mounting position (drawing); so a buyer can prepare before buying the item.
Re: Hemi block engine mount [Re: 440Jim] #2761017
04/07/20 09:12 AM
04/07/20 09:12 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I thought you had to use the Schumacher mounts?
