1970 Challenger Seat Belts?? #2757523
03/30/20 10:30 AM
03/30/20 10:30 AM
Ohio
fiddlestix Offline OP
Ohio
I am looking for a reasonably priced 3 point conversion seat belts for my 70 Challenger with bucket seats. My Challenger does have the anchor plates in the sail panel for belts. I thought I read somewhere that some cars didn't. I am looking at SeatbeltsPlus.com and they list them for 71-74 Challenger. Can anyone tell me why they won't work on a 70? Does anyone have any other sources for good belts at a reasonable cost?
Thanks for your help!
Re: Seat Belts?? [Re: fiddlestix] #2757530
03/30/20 10:49 AM
03/30/20 10:49 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
FWIW - A buddy of mine got some 3-points for his '70 Dart; they're the ones most commonly seen, with a big floor-mounted reel.
The bracket on the reel is in the wrong place, so an extension is included, but:
The extension becomes a hinge, rendering the location less secure and less effective.
The belt is rearward, making it clumsy to reach & complicating rear seat access.
Reel is too large to fit between seat & door or seat & inner rocker.
It can be made to work by drilling into the rocker, but you'll need access to the backside (inner rocker or floor) to secure it.
Another method would be an adapter plate, using factory floor hole + another hole drilled in.
If you can use a later 1st-gen Challenger 3-point, that's likely best, but I quit researching it when he decided to just use seat belts.
I keep thinking that there has to be an OEM solution from another vehicle...
Re: Seat Belts?? [Re: topside] #2758399
04/01/20 01:06 PM
04/01/20 01:06 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
All 70 challengers except convertibles have the upper mount.
5549 post on old board
Re: Seat Belts?? [Re: 05dakota] #2759403
04/03/20 11:24 AM
04/03/20 11:24 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
I have the correct black belting. 5/yard. locate hardware and you are all set.
Re: Seat Belts?? [Re: MO_PA] #2759640
04/03/20 08:58 PM
04/03/20 08:58 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
I have no answer for you but the screen name is great !
Re: Seat Belts?? [Re: Jjs72D] #2759642
04/03/20 09:00 PM
04/03/20 09:00 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Maybe I do have an answer.
Try XV Motorsports. I know a few guys that bought their 3 point retractable front belts. Great quality stuff at a good price.
Re: Seat Belts?? [Re: Jjs72D] #2760117
04/04/20 07:03 PM
04/04/20 07:03 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I have a 70 B body, so I can’t speak for the E body, but I doubt the results would be different. I purchased the retrofit 3 point belts sold by Classic Auto industries and am very pleased. These use the two factory bolt locations. I don’t think the arm at the base compromises the belt in any way. Only two minor drawbacks I can see. The first being the belt retractor. It need a little help to reel in the belt when you disconnect. The spring could be loaded a bit tighter. The second is the height at which the shoulder section crosses my body. I’m 6’1” and it nearly misses rubbing my neck. I haven’t had a shorter person ride with me to see where it hits them. All in all, I’m a happy customer.
A85F4CEC-367D-4247-8807-03AA929F4C01.jpeg934CDAC2-C8DB-4899-B59E-6DABCCE29E96.jpegBC14BC3D-CC16-4441-AC4F-F47E8CED7DF4.jpeg05CAFC66-A94B-4375-A4D7-84632BB6AC05.jpeg
I’m listening.
Re: Seat Belts?? [Re: Big Bad Bee] #2760158
04/04/20 08:42 PM
04/04/20 08:42 PM
Norfolk County , Ontario
WORKER_BEE Offline
WORKER_BEE  Offline
They don't list E-bodys but they may be worth calling.
www.seatbeltsolutions.com
1969 Super Bee Six Pack
1969 Charger R/T SE
1968 Crown Coupe
Re: Seat Belts?? [Re: WORKER_BEE] #2760762
04/06/20 02:10 PM
04/06/20 02:10 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
Re: Seat Belts?? [Re: 05dakota] #2761068
04/07/20 11:16 AM
04/07/20 11:16 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
I ordered these for my 71 Challenger Hard Top but have not installed yet:
https://www.wescoperformance.com/long-sash-seat-belt-starburst.html
Re: Seat Belts?? [Re: wally426ci] #2761087
04/07/20 12:27 PM
04/07/20 12:27 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Nice belts if you don’t mind a mix of GM in your interior
Abe Lincoln
Re: Seat Belts?? [Re: wally426ci] #2761089
04/07/20 12:35 PM
04/07/20 12:35 PM
moparx Offline
moparx  Offline
thanks for that wesco link. those look promising for my charger.
i'll just have to get in touch with them to get a color chart so i can chose the right color to go with my interior.
beer
Re: Seat Belts?? [Re: dart4forte] #2761152
04/07/20 03:15 PM
04/07/20 03:15 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
What is GM about these?
Re: Seat Belts?? [Re: moparx] #2761156
04/07/20 03:48 PM
04/07/20 03:48 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
beer
These are what I used also.
