Old Holley Carb Quesion #2760624
04/06/20 07:40 AM
04/06/20 07:40 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am reworking an old carb of mine (650cfm, [ 0-80783C? The numbers have been ground off in the past], vacuum secondary, and I have a question.
On the base plate there is a jet (45?) that is connected to the round hole on the side (purple). It appears to be a vacuum port or a purpose vacuum leak. Can someone explain what this port is used as?
Thank you,
Re: Old Holley Carb Quesion [Re: YO7_A66] #2760631
04/06/20 08:09 AM
04/06/20 08:09 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
automatic choke pull off port for the choke blade.
Re: Old Holley Carb Quesion [Re: lewtot184] #2760634
04/06/20 08:20 AM
04/06/20 08:20 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thank you! I wanted to understand it before I put things back together. up
Re: Old Holley Carb Quesion [Re: YO7_A66] #2761720
04/08/20 09:30 PM
04/08/20 09:30 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
It's only the electric choke i think. Manual choke carbs have a plate that blocks that hole on the side of the carb. I've never seen one with a jet on the base plate though. Hope that thing is locktight'd in.
Re: Old Holley Carb Quesion [Re: mopowers] #2761862
04/09/20 11:26 AM
04/09/20 11:26 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
That jet is in TIGHT! It started to break when I tried pulling it out.
Thanks!
Re: Old Holley Carb Quesion [Re: YO7_A66] #2762039
04/09/20 08:16 PM
04/09/20 08:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks!
I've never seen one with a jet on the base plate though. iagree
I'd definitely do some research on that before I put it on a motor. twocents beer
