Re: Hemi block engine mount [Re: Dragula] #2761084
04/07/20 12:10 PM
04/07/20 12:10 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Originally Posted by Dragula
Love it when people buy race parts and then expect to use them like stock factory parts...
Randy I was right there with you but in these trying times I used my social distancing...but if they complain about power steering the mask comes off.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Hemi block engine mount [Re: 440Jim] #2763978
04/14/20 07:41 PM
04/14/20 07:41 PM
QLD Australia
Keith Black® Offline
QLD Australia
Originally Posted by 440Jim
Interesting. The block I bought in 2014 had three mount holes to clear the double side bolts for the main caps.
These are my measurements, FWIW.
440Jim you are correct. The mounts are in the factory location with the exception of the top bolt which is slightly lower. This is so it doesn't go into the main oil galley.
Most modify a stock mount bracket to fit. Also, we are making brackets now (about to trial fit) that will be available.
Darren Beale
Keith Black Racing Engines®
Re: Hemi block engine mount [Re: Keith Black®] #2764078
04/15/20 05:39 AM
04/15/20 05:39 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Please let me know if and when or would be a set available for a 68 B-body.
