Pushrod length Q?
#2760109
04/04/20 06:50 PM
04/04/20 06:50 PM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
How much shorter can a pushrod be from "optimal", and still be acceptable? The intake needs to be 9.400" long, exhaust needs to be 9.350" (3/8" dia, .083 wall, 3/8" ball, 5/16" cup). I have a nice set of almost new Smith Brothers pushrods that measures 9.355". They will be good for the exhaust, wondering if they would also be acceptable to use them on the intakes, or just order up a new set? This is a 557ci, w/ a solid roller. Thanks, Brian
Re: Pushrod length Q?
[Re: sasquatch]
#2760227
04/05/20 02:45 AM
04/05/20 02:45 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Since we are talking pushrod lengths. How much shorter is a low deck rod over a raised block? I am going to build a length checker for my 400. Curious where to start.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: HOTMOPR]
#2760355
04/05/20 12:14 PM
04/05/20 12:14 PM
dartman366
Mt. Vernon, Ohio
low deck is approx, 1.00 shorter, .980 i think is the factory dimention
[Re: dartman366]
#2760367
04/05/20 12:42 PM
04/05/20 12:42 PM
RapidRobert
On a side note you might check out the B3 utube vid on rocker geometry. Easy to grasp & he's the guru on this. Basically you want the rocker/valve to be at at right (90) angle to each other at 1/2 cam lift & changing rocker height alters this (can be hard to do on our Mopars) & that this geometry sets the pushrod length needed not the other way around (with your preload included in this).
[Re: '72CudaRacer]
#2760395
04/05/20 02:30 PM
04/05/20 02:30 PM
fast68plymouth
So. Burlington, Vt.
Imo, it’s more critical to have the length optimized on some types of rockers more than others.
On something like a Jesel or T&D, I def wouldn’t be running the adjusters outside of the acceptable range...... especially with high spring loads.
