Re: Advancing camshaft [Re: fast68plymouth] #2758432
04/01/20 02:53 PM
04/01/20 02:53 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Not V8 but when Shelby did the 2.2's for 1983 he found the stock cams were too retarded after he milled the blocks 0.030". So he had Chrysler make a Shelby spec cam sprocket to advance the cam 9 degrees to re-centerline it due to the belt pulling the cam into retard with the deck mill. When I threw the degree wheel on it it was 5 degrees advanced. I did use the Cam advance keys to set it at 8 degrees total and it ran stellar.
Years later working on a fairly stock 2.5 in a Shadow ES 5 speed. I removed Balance shafts. I had a measured 10:1 comperssion, and a 240/252 0.460" lift DC cam. I played with Cam keys but ended using the stock key and slipping the timing belt 1 tooth advanced, that was 9 degrees per tooth. Before I advanced the cam and 'Granny' shifted at 3500 RPM it got 32 MPG. Advancing the cam 9 degrees, that car had gained so much bottom and mid range power but nothing up above 5,000 RPM. Again, Granny shifting it then got 41 MPG. This was a daily driver for commuting 82 miles a day.
But back in the 1980's playing with a dead stock 318 with a Performer manifold and 600CFM Holley we ran a 360 2bb cam. It was strong and with a 74 Dart Swinger and 2.76 gears gave 20 MPG. Then we put a 4 degree advanced chain and it boosted the BUTT DYNO a lot and when babing it, it got the best of 25 MPG but avareged 23 MPG.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Advancing camshaft [Re: ZIPPY] #2758433
04/01/20 02:54 PM
04/01/20 02:54 PM
my own world
theraif Offline
theraif  Offline
my own world
twocents talked about 10* for one of my wagons i had just to get it moving
Re: Advancing camshaft [Re: fast68plymouth] #2758454
04/01/20 03:40 PM
04/01/20 03:40 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Originally Posted by fast68plymouth
Originally Posted by B1MAXX
All kinds of cams, engines. The one I remember it helping was a cam with a lobe sep angle of 112.
I’ve never done it....... and don’t think I would....... but it would be interesting to know the whole combo on something where that worked.
little chevy 355 cubes brodix track 1's as I recall long time ago, Nova 5.13's at say 2800...lots of fiberglass ect. transbrake with chip removed.I want to say we even moved the rockers 1.7's to the exhaust to make it work.
now I try to put everything in at 106, or as close as possible, where the valve to piston clearance works out.
Re: Advancing camshaft [Re: B1MAXX] #2758465
04/01/20 04:06 PM
04/01/20 04:06 PM
Cab_Burge Online work
Cab_Burge  Online Work
You really need to know if people talking about advancing the cams are talking about crankshaft degrees or camshaft degrees, correct work
I always use crankshaft degrees when talking about advancing camshafts but people some don't work scope
The first camshaft I had to degree to get the motor to run halfway decently was a 392 hemi in a V drive flat bottom ski boat, I didn't know about cam timing and degree checking off of the lifters instead of the valves at that time or about lobe separation angles. realcrazy I do now up
The cam was a Sig Erson solid roller cam for ski boat racing and it was ground 8 crankshaft degrees retarded from 110 LSA on the intake lobes, they recommended running the intake lobe center at 108 and when I finally got to checking it properly it was installed at 118 ILC puke They insisted it was anything but their cam being ground wrong, they wouldn't replace it with one ground correctly down
I ended up using the LSA method to get it where they wanted it by using offset keys on both the cam and crankshaft wrench The only good thing that I learned form that is how to use LSA for cam timing verification and cam installing off of the intake lobes up BTW, I always verify the exhaust lobes to make sure the cam is ground on the LSA the cam card says it is scope If it is a 108 LSA grind and installed at 104 after top dead center on the intake lobes on the crankshaft the exhaust lobes should be in it at 112 before top dead center to be ground correctly scope I have seen more than one cam ground wrong on the LSA from several different cam companies whiney
I never bought another Sig Erson cam after that one though thumbs
Never, NEVER install any cam by aligning the dots and ASSUMIMNG it is installed straight up, always verify scope twocents
OP, I've installed and ran and raced a bunch of motors and check all the cam timing and tested a bunch of cams in different motors advanced, straight up and retarded, none of the Mopar V8 motors like straight up or retarded, they all like the cams advanced at least four crankshaft degrees up None of them liked or ran faster or made more power advanced more than six crankshaft degrees shruggy work
IHTHs
Re: Advancing camshaft [Re: Cab_Burge] #2758470
04/01/20 04:19 PM
04/01/20 04:19 PM
portland, ct
Since1822 Offline OP
portland, ct
IHTHs
Cant thank all of you guys enough for posting your knowledge to help me out. As always, much appreciated. I wish I did this much research when I was in school lol. Learn a lot here
Re: Advancing camshaft [Re: Since1822] #2758472
04/01/20 04:25 PM
04/01/20 04:25 PM
I'm still learning via the on the job training, DANG Murphy any ways grin
AKA aside that cam was a real painful lesson in motor building and theory whiney
Re: Advancing camshaft [Re: Cab_Burge] #2758475
04/01/20 04:38 PM
04/01/20 04:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If you use a typical 9 way timing set, you can get within 1deg of where you want the cam installed........ no matter how far off it is.
Those sets can go +/- 8*, which is 1* past the 1/2 way point to the next tooth over.
So, if you’re more than 8* off...... move the the timing set over a tooth, and come at the c/l from the other side.
Re: Advancing camshaft [Re: Cab_Burge] #2758477
04/01/20 04:45 PM
04/01/20 04:45 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Some of the car companies (Ford specifically) moved their cams around by changing the crank and cam gears and not the cam. 1970 429 Ford cam gears when used on 75 or up 460's turn trucks that won't spin the tires on wet grass into trucks that will smoke the tires on any kind of pavement. That kind of retarded camshaft also effects gas mileage in the worst kind of ways. Sold many many earlier style timing sets to Ford car and truck owners after explaining the difference to them and never had a complaint from any of them.
Re: Advancing camshaft [Re: John Brown] #2758489
04/01/20 05:00 PM
04/01/20 05:00 PM
I had a friend who owned and love Fords tell me that years ago, he had seen a 460 in a 1971 Lincoln Mark 4 loose a lot of power when they change the timing set in it to avoid it skip timing when it had around 80,000 miles on it, they bought the timing set from the local Ford dealership and they sold him one off the shelf they had in stock for a 1986 ford truck 460 motor, they went through a bunch of pain and work to figure out what had happened and fix it wrench
Re: Advancing camshaft [Re: John Brown] #2758491
04/01/20 05:02 PM
04/01/20 05:02 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if the builder is used to small block chevy engines then he may have been buying cams with LSA's anywhere from 106-102. put some advance in those cams, specifically short track, and you'll end up with around 100 or less installed centerline. I don't think what the OP's doing and what the builder does is apples to apples. i'd change it.
Re: Advancing camshaft [Re: lewtot184] #2758550
04/01/20 06:40 PM
04/01/20 06:40 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
This may help understanding cam advance and intake centerline.
When the rod and the crank throw are perpendicular, this is the point of maximum piston acceleration.
Some would argue this is also the point of maximum draw/pull on the intake mixture, although this point
is not quite an exact mathematical relationshp, but it's probably not too far off.
For most engines, the crank throw and the rod are perpendicular at approx 70 degrees ATDC to around 76 degrees ATDC,
depending on rod length and total stroke of course. 70 degrees in a "short rod" motor, 76 degrees in a "long rod" motor.
This is A LOT earlier than 100 degrees ATDC, which is considered pretty advanced for intake valve centerline.
The hidden question is: Should the intake valve be at max lift at the point of max piston acceleration for max breathing ?
Because of this, it should not be surprising that advancing the cam, i.e., the intake centerline, generally shows
up as higher torque output of the engine (in a given RPM range). It also shows how much of a compromise cam design
really is, they are not AT ALL ideal, but, it's the best we've got.
Edit: Replace the phrase "piston acceleration" with "piston velocity". The degree numbers are correct, everything else
is correct. I can't believe I made that mistake.
Re: Advancing camshaft [Re: hemienvy] #2758575
04/01/20 07:24 PM
04/01/20 07:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Another argument: a short rod has significantly faster piston acceleration ATDC, and initiates vacuum at the intake valve curtain earlier (for which Vizard has made a good case as not merely useful but indispensable).
It also has slower motion ABDC, and captures a greater percentage of the stroke at the same point of cam & crank rotation than a long rod. Will show higher CCP and stop reversion at lower RPM.
Boffin Emeritus
Re: Advancing camshaft [Re: polyspheric] #2758594
04/01/20 08:09 PM
04/01/20 08:09 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
the highest depression is at the overlap event...at least from my understanding.
Re: Advancing camshaft [Re: B1MAXX] #2758605
04/01/20 08:30 PM
04/01/20 08:30 PM
gregsdart Offline
gregsdart  Offline
I have to think that the overlap events have more influance on power when a cam is moved than closer to max valve lift. Getting that. Intake charge moving through the intake valve at low lift is pretty important. To me it reminds me of the importance of 60ft and 330 ft times. They are the base of a great ET. Bad 60 or 330 numbers can't be compensated for.
Look at a 440 with unported iron heads. It responds to a lot of advance AND overlap because of the poor heads.
