Hyperspark coil with low mount alternator #2758587
04/01/20 07:46 PM
04/01/20 07:46 PM
AndyF Offline OP
AndyF  Offline OP
I had a Moparts member ask me about mounting a Hyperspark coil on the end of the cylinder head above the alternator. There wasn't any easy way to do it so I designed a bracket that makes it all fit. The bracket and the alternator mount share the same bolt location so they have to fit together. But once that is figured out it goes together fairly easily.
Re: Hyperspark coil with low mount alternator [Re: AndyF] #2758750
04/02/20 09:08 AM
04/02/20 09:08 AM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Man, I'd love to hang out with you for just one day! The things I could learn! Looks great, as do all your fabrications!
