Are All TA (340 Six Pack) Blocks Build Date Stamped? #2757685
03/30/20 06:16 PM
03/30/20 06:16 PM
canada
lrtexpress Offline OP
canada
Can anyone confirm if all or only partial TA (Six Pack) blocks received build date stamps? Realize warranty blocks may be an example of no build date. My AAR block is date stamped on front side of the block . Seen others that appear to be correct to the car (numbers matching) but do not have build date stamps, is this a factory oversight? , common or an issue?
Re: Are All TA (340 Six Pack) Blocks Build Date Stamped? [Re: lrtexpress] #2757698
03/30/20 06:32 PM
03/30/20 06:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Each block should be assessed on its own.
Other details are needed for that;
VIN stamp or not?
If not, warranty tag or not?
Is the VIN stamp original or not?
340 CID or a later one for the racers stamped 355 for the CID?
And as always, photos always help.
