Re: Race fuel prices?? [Re: hp383] #2758313
04/01/20 09:34 AM
04/01/20 09:34 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Originally Posted by hp383
Originally Posted by Doc Fiberglass
Is there any EASY AND SIMPLE WAY to measure and MAKE this E85 mix dead on or made even a tad richer ?
The problem I have is I keep drinking the ethanol I make and never have any to blend.
That should keep the virus away whistling
Gus beer
64 Plymouth Savoy
Dana 60
Re: Race fuel prices?? [Re: Deepockets] #2758323
04/01/20 10:19 AM
04/01/20 10:19 AM
gregsdart Offline
gregsdart  Offline
Originally Posted by Deepockets
Hey Greg, I switched to E-85 (out of the pump)in the dragster at the end of last year. I'm at 14-.3 comp an it's working well. First of the year I ran a best of 7.37 @ 180. It's a pretty big camshaft that brings down some cylinder pressure. $2.99 per gallon.
Great info Don! Glad it's working for you. For lower compression motors ( say less than about 12.5/1)
I posted in another forum about mixing to a lower ethanol content for two reasons. By going lower , like to 50 or 60 pct ethanol you can always adjust the pump e85 down to what percent you want. The other reason is at some reduced percent (e50?) You should be able to run the mix in a box stock race holley. A e50 mix should be able to go richer to the 20 percent higher fuel flow required by the E50 versus reg gas. So if the fuel system can handle the extra flow and the carb a guy has can flow the right mixture, for some guys it could be a real win win.
Re: Race fuel prices?? [Re: gregsdart] #2758367
04/01/20 12:00 PM
04/01/20 12:00 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I think 110 was $8.80 in early March when I checked. As other have stated it doesn't follow the trend of regular pump gas prices. I've never seen race fuel go down in cost...
Re: Race fuel prices?? [Re: DusterKid] #2758443
04/01/20 03:21 PM
04/01/20 03:21 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
This is the very reason I went with a pump gas motor. I got tired of the high price of race gas and hard to find it. I run 93 octane .
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Race fuel prices?? [Re: D-50] #2758739
04/02/20 08:45 AM
04/02/20 08:45 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
We pay $410 a drum for VP Blue which is C12.
We pay $580 a drum for 113.
