Front speaker mounting #2755736
03/25/20 11:03 AM
03/25/20 11:03 AM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
69 B-body dash mounted center front speaker has a mounting plate with an offset. It looks like it can mount either way. Does the long side of the offset go to the front or rear? Also wire terminals are they to the left or right? Thanks.
Re: Front speaker mounting [Re: NITROUSN] #2755741
03/25/20 11:16 AM
03/25/20 11:16 AM
Lansing, MI
70gtx440dana Online content
70gtx440dana  Online Content
Lansing, MI
Center speaker wiring is typically pointed toward the LH (driver side). This is also the side of the radio where the speaker wires are attached. Can't remember if the bracket has a specific orientation.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Front speaker mounting [Re: 70gtx440dana] #2755800
03/25/20 01:16 PM
03/25/20 01:16 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Thanks. I sort of figured the wires would be on the left. I just would like to mount it correctly even though no one will see it. Hopefully someone will have a mounting answer.
Re: Front speaker mounting [Re: NITROUSN] #2755821
03/25/20 01:45 PM
03/25/20 01:45 PM
Wheatfield, NY
Cuda340 Online work
Cuda340  Online Work
Wheatfield, NY
Correct, wires towards the cluster (drivers side)
Re: Front speaker mounting [Re: Cuda340] #2755965
03/25/20 05:57 PM
03/25/20 05:57 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Right. I just need to know which way the offset goes on the speaker mount to dash frame.
Re: Front speaker mounting [Re: NITROUSN] #2757518
03/30/20 10:22 AM
03/30/20 10:22 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Not sure if this will help. This is a dash assembly I pulled out of a 4 door parts car that was pretty much unmolested. It looks like the bracket has a front/back offset.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Front speaker mounting [Re: RoadRunner] #2757536
03/30/20 10:57 AM
03/30/20 10:57 AM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Thanks. That confirms what I have done. At first it seemed like it could go either way. Once I finished the sub assembly and installed the defroster ducts it would only fit one way due to the defroster duct angular mount studs. Thanks again.
Re: Front speaker mounting [Re: NITROUSN] #2757636
03/30/20 03:18 PM
03/30/20 03:18 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm pretty sure that bracket only fits one way.
