1971 Cuda Road Lamp Wiring Question #2757525
03/30/20 10:35 AM
03/30/20 10:35 AM
Arizona
Jeffaary Offline OP
Jeffaary  Offline OP
Arizona
On a 1971 Cuda with road lamps, where the wire passes through the firewall is there a connector or just a grommet?
Re: 1971 Cuda Road Lamp Wiring Question [Re: Jeffaary] #2757827
03/30/20 11:54 PM
03/30/20 11:54 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
To directly answer your question there's a small section of wire past the firewall grommet that protrudes into the engine bay...At the end of that would be your connector...While there are differences in the harness between 70 and 71 that section appears to be very close if not the same...
Re: 1971 Cuda Road Lamp Wiring Question [Re: screamindriver] #2759528
04/03/20 03:30 PM
04/03/20 03:30 PM
Arizona
Jeffaary Offline OP
Jeffaary  Offline OP
Arizona
Thank you very much for the picture and information.
