Master cylinder bolt #2756033
03/25/20 08:55 PM
03/25/20 08:55 PM
PA
70HemiGTX Offline OP
PA
I have 2 old master cylinders from my 70 GTX. NON power drum brakes. Neither was mounted on the car when I got it. One does not have any mounting bolts in it, the other has 4 bolts pressed in facing into the car's dash that would get nuts on them from under the dash and holding he clutch/brake pedal frame in place. Which is correct?
Re: Master cylinder bolt [Re: 70HemiGTX] #2756044
03/25/20 09:54 PM
03/25/20 09:54 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Nuts under the dash on a 69 RR,I would think they would be the same on a 70 GTX.
Re: Master cylinder bolt [Re: pushbutton] #2756266
03/26/20 06:56 PM
03/26/20 06:56 PM
VA
dragon slayer Offline
VA
Non power drums stud in master cylinder. If it was power drum, the studs are on the booster so no studs in MC.
Re: Master cylinder bolt [Re: dragon slayer] #2756320
03/26/20 10:28 PM
03/26/20 10:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
yep
Re: Master cylinder bolt [Re: gtx6970] #2756412
03/27/20 09:14 AM
03/27/20 09:14 AM
SE Pa.
LimeliteAero Offline
SE Pa.
getting to those suckers is one of the worst projects Ive done. If you're not young or smallish, take the seat out.
Re: Master cylinder bolt [Re: LimeliteAero] #2756481
03/27/20 01:41 PM
03/27/20 01:41 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
A flat-rater showed me a trick...a 24" 1/4" drive extension with a 1/2" deep swivel socket.
Re: Master cylinder bolt [Re: LimeliteAero] #2756904
03/28/20 02:56 PM
03/28/20 02:56 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This old fat boy agrees with you 100%.
Re: Master cylinder bolt [Re: 6PakBee] #2756941
03/28/20 04:35 PM
03/28/20 04:35 PM
PA
PA
[b][/b]Great. So I should put the master cylinder in before I even think of putting the dash in and or the seats or the shifter or anything else. Because I sure as heck can't twist like a pretzel any more. Not that I really could before.
Thanks for the info though. I bought one of those new master cylinders off of ebay to put in the car. I know some of the plating isn't correct, but the shape of the lid is perfect. So that's a bonus. I'll transfer the studs over to the new master cylinder.
Thanks everyone for the help. up
