3rd gen Dakota front coil spring interchange? #2756731
03/28/20 07:53 AM
03/28/20 07:53 AM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Asked on truck forum but no help. Thought maybe someone on the Q & A forum would know since it has more traffic. up
Finishing up 5.9 swap into the Dakota and obviously need to swap the front coils as the nose is very low due to it being a V6 truck. My question is will 1st gen 2wd Durango coils work since they are more plentiful in the pullaparts? Checking different part #s at RA shows very little interchange and that a 4.7 is different than a 5.2/5.9, I'm guessing since the 4.7 is lighter.
Anyone have some input?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 3rd gen Dakota front coil spring interchange? [Re: I_bleed_MOPAR] #2756856
03/28/20 01:32 PM
03/28/20 01:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The Hollander Interchange shows '89-'96 6-cylinder interchange but not 318. '97-'03 no interchange with earlier.
Re: 3rd gen Dakota front coil spring interchange? [Re: John_Kunkel] #2756976
03/28/20 06:54 PM
03/28/20 06:54 PM
Buford, GA
Buford, GA
Thanks, John, but I have a 2000 Dakota (considered 3rd gen I'm told) and was wondering if anyone had some experience with using Durango coils on a Dakota. Around here V8 Dakotas (5.2/5.9) are few and far between in the pullaparts but Durangos are plentiful. up
Tim
'71 Charger 383/727
Re: 3rd gen Dakota front coil spring interchange? [Re: I_bleed_MOPAR] #2756994
03/28/20 07:44 PM
03/28/20 07:44 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If you click on the part number at Rockauto it'll give you the applications.
In this case the 360 2000 Durango springs are also listed for the 2000 Dakota.
Re: 3rd gen Dakota front coil spring interchange? [Re: Sniper] #2757034
03/28/20 10:05 PM
03/28/20 10:05 PM
God's Country Maryland
GODSCOUNTRY340 Offline
My '04 Dakota SXT 4.7 has torsion bars in front, not coil springs. When did they start putting torsion bars in the Dakotas?
Re: 3rd gen Dakota front coil spring interchange? [Re: GODSCOUNTRY340] #2757046
03/28/20 10:29 PM
03/28/20 10:29 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
my 96 4wd has torsion bars, all of my 2wd Dakotas have had coil springs in front from 89-99. (covers more than 1 gen/body design)
Re: 3rd gen Dakota front coil spring interchange? [Re: volaredon] #2757119
03/29/20 09:10 AM
03/29/20 09:10 AM
Buford, GA
Buford, GA
4wd uses torsion bars on Durangos and Dakotas. 2wd use coil springs. I knew about RA listing application by part number. up What I'm trying to find out is if anyone had first-hand experience using, say, springs from an '01-'03 Durango 5.9 or '98-'99 (according to RA these 2 years don't even interchange) Durango 5.2 or 5.9. I do run across these pretty regularly. I would list '97-'99 5.2 or 5.9 Dakotas but cannot remember ever running across one in a pullapart. work
Tim
'71 Charger 383/727
