WHICH ONE IS IT? #2756774
03/28/20 09:57 AM
03/28/20 09:57 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Maybe more confirmation than a question.
78 Magnum, 318-2, leanburn converted: Lately it randomly won't start, I only have to turn the key off and back on, usually by the 3rd try it'll start, and it's not every time I drive it. I have noticed at times the engine "jumps" or seems to fire when I turn the switch off. I seem to recall that meant the pickup coil was going bad. Wonder if maybe the ICU may be the culprit? To date it's not left me set. Yet
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: WHICH ONE IS IT? [Re: Magnumguy] #2756846
03/28/20 12:56 PM
03/28/20 12:56 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Could be either, lately I had a slant six doing that and seemed like if I got it rolling over it would go as soon as I let off the key which to me meant the start side had went away so put the original box back on and was back to normal. That was an orange box that went bad and had a place on the back side where you could see it had heated up and left a burn mark
Re: WHICH ONE IS IT? [Re: 500ciDuster] #2756875
03/28/20 01:57 PM
03/28/20 01:57 PM
S.E.Ohio
S.E.Ohio
I'll take it off and inspect it. Thanks
Re: WHICH ONE IS IT? [Re: Magnumguy] #2756885
03/28/20 02:19 PM
03/28/20 02:19 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Yes, if you have a another box maybe try it.
Re: WHICH ONE IS IT? [Re: Magnumguy] #2756929
03/28/20 04:03 PM
03/28/20 04:03 PM
Courtenay, B.C.
DarrenS Offline
DarrenS  Offline
Courtenay, B.C.
I would be suspecting the ignition switch
Re: WHICH ONE IS IT? [Re: DarrenS] #2756939
03/28/20 04:30 PM
03/28/20 04:30 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
My Barracuda did that when the bulkhead connector failed on the start wire from the ignition switch.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: WHICH ONE IS IT? [Re: Dave_J] #2757166
03/29/20 11:18 AM
03/29/20 11:18 AM
moparx Offline
moparx  Offline
another area to inspect is the steering column connection to the harness.
i have seen, and repaired, many over the years. that connection becomes corroded or loose, then arcs and burns/heats the connection, sometimes melting the connector block.
beer
Re: WHICH ONE IS IT? [Re: moparx] #2757988
03/31/20 12:51 PM
03/31/20 12:51 PM
S.E.Ohio
S.E.Ohio
Swapped out what appears to have been a repo box and installed one that is a Chrysler unit ( supposedly ).
Seems to run different (not so much better just different) but starts better all the time. We'll see.
