I am not familiar with this slider set up can someone explain?
Its a roller bearing back where the leaf spring attaches at the rear... as to on the street.. the guys I put them on for.. none had any issues.. it can make it handle a slight bit better due to less movement(side to side)
I drive mine on the street a lot, They sell a thick hard nylon block to replace the noisy bearings, custom built 4X4 trucks use sliders a lot !!! it allows the spring to work much better.
Want to install mine?
I quit doing side work after I retired.. they are pretty easy to put on.. if you put them straight on they will lower the back of the car some(about 1")
Those sliders need to be moved forward.The slider hits the front of the mount at the launch. The bolt/roller should be 3/4 to the back of the slot,not in the middle. Don't ask how I know
Yep.. I use to mount them at 3/4 .. I watched that vid like 6 times to see if they hit
would the type of shock or leafs have effect on that 3/4" measurement?
It shouldnt unless the springs are shorter or longer.. the shock shouldnt
Re: Leaf Spring slider Tech
[Re: MR_P_BODY]
#2756430 03/27/2010:43 AM03/27/2010:43 AM
