Re: Max Wedge oil pan
[Re: dvw]
#2761500
04/08/20 02:03 PM
04/08/20 02:03 PM
Posts: 4,206 New York
polyspheric
New York
The radius at the corner cut is excellent. IDK how large it should be for best strength (obviously 1" is not needed), but any is better than a 90 degree cut. Even if it's been in use for a while with no bad results, that sharp corner flexes a bit every time you work the suspension hard, and that corner will begin to tear eventually. No, it never happened to me, it's just my OCD acting up. Be safe!
Boffin Emeritus
[Re: A727Tflite]
#2761653
04/08/20 06:55 PM
04/08/20 06:55 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I used the stock 1970/71 6 quart Hemi and 440 six pack oil pan with the stock 440 6 pack 3/8 oil pick up in my old street pump gas Duster that I shifted at or above 7000 RPM in 1 and 2nd gear and it would rev at or above 7000 RPM in high gear in the 1/4 mile with no oiling issues with loose rod and main bearing clearances (.0032+ on the rods and .0040+ on the full narrow groove mains)and 5W20Wt oil as long as the oil level was above the add mark before the 1/4 mile runs If it was at or below the add mark before the 1/4 miles passes it would start to loose oil pressure when I let off around 200 to 300 ft. past the finish line, adding oil to bring it up the full line fixed it
[Re: Cab_Burge]
#2761682
04/08/20 08:05 PM
04/08/20 08:05 PM
polyspheric
New York
Is the pan baffled to prevent oil from climbing the back wall?
Boffin Emeritus
