Page 3 of 3 1 2 3
Re: Ardun on the dyno [Re: mickm] #2755825
03/25/20 01:51 PM
03/25/20 01:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The Ardun sounds nice, and bigger than it is.
The rocket car is hysterical !
Re: Ardun on the dyno [Re: mickm] #2755954
03/25/20 05:38 PM
03/25/20 05:38 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Thank you for taking the time to share this. I enjoyed it
Re: Ardun on the dyno [Re: MoonshineMattK] #2755975
03/25/20 06:24 PM
03/25/20 06:24 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If it was mentioned I missed it.....
What’s the cubic inch?
Re: Ardun on the dyno [Re: fast68plymouth] #2756038
03/25/20 09:31 PM
03/25/20 09:31 PM
If my memory serves me correct the 1949 to 1953 Ford motors where 239 C.I., the same year Mercury where 254 C.I. I have no idea how much the 4.0 inch stroker cranks add to either motor, CRS on the bore sizes also whiney
Re: Ardun on the dyno [Re: Cab_Burge] #2756047
03/25/20 10:10 PM
03/25/20 10:10 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
https://en.wikipedia.org/wiki/Ford_flathead_V8_engine
Re: Ardun on the dyno [Re: John Brown] #2756056
03/25/20 11:07 PM
03/25/20 11:07 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Boffin Emeritus
Re: Ardun on the dyno [Re: fast68plymouth] #2756090
03/26/20 02:01 AM
03/26/20 02:01 AM
California
mickm Offline OP
mickm  Offline OP
California
Around 280ci. I don't remember exactly, but somewhere in the 280's.
Re: Ardun on the dyno [Re: mickm] #2756126
03/26/20 09:42 AM
03/26/20 09:42 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
back in the late 40's-early '50's 300+ real horsepower would have been a big deal. put that engine in a 2000lb or less roadster and you could have a real hot rod for it's time era.
several years ago a friend gave me some early hot rod mags. I found them to be a real gas to read. one of the mags is Hot Rod Your Car, copyright was 1952. back then Racer Brown was the tech editor for Hot Rod magazine. they go thru all the American engines at the time and it really gives an insight on how these guys did things with virtually no tech. to know what I know now and to have a time machine.
Re: Ardun on the dyno [Re: madscientist] #2772684
05/09/20 01:41 AM
05/09/20 01:41 AM
Livonia,MI
1968fury Offline
1968fury  Offline
Livonia,MI
Originally Posted by madscientist
Originally Posted by TRENDZ
My only experience with a flat head ford was with my neighbor. He’s building an “A” hotrod. Wanted me to relive the block. I had no idea what he was talking about, until he showed me😀. Turned out nice.
I've actually done a lot of flatheads, and flowed a half dozen or maybe a couple of more and relieving the chamber is bad. Very bad. They also LOVE 50 degree seats.
Wrong very wrong. On a full race or blown flathead there are benefits to relieving. Don't believe me check out joe abbins books he does extensive flow testing.
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
Re: Ardun on the dyno [Re: 1968fury] #2772784
05/09/20 10:35 AM
05/09/20 10:35 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Nice, it even sounds like a Hemi!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Ardun on the dyno [Re: 1968fury] #2772894
05/09/20 02:58 PM
05/09/20 02:58 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I still want someone to explain how they flow test these. No answer on that one yet.
Re: Ardun on the dyno [Re: TRENDZ] #2772923
05/09/20 04:41 PM
05/09/20 04:41 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
One guys approach. Others have cut up a scrap block so they can set the cylinder on top of the flow bench. Others have made a model cylinder out of wood and put in metal valve seats to experiment with seat angles and machined a test head out of plexiglass.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Page 3 of 3 1 2 3
