Page 2 of 3 1 2 3
Re: Leaf Spring slider Tech [Re: Wirenut] #2755827
03/25/20 01:54 PM
03/25/20 01:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by Wirenut
I am not familiar with this slider set up can someone explain?
It mounts to the rear of the leafspring replacing the shackle.
Supposed to keep the spring rate from changing and let the spring move freely.
'63 Dodge 330
11.19 @ 121 mph
Re: Leaf Spring slider Tech [Re: GY3] #2755833
03/25/20 02:01 PM
03/25/20 02:01 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Is it something you would employ with only a mono leaf Caltrac set up?
Re: Leaf Spring slider Tech [Re: Wirenut] #2755843
03/25/20 02:19 PM
03/25/20 02:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I see no reason they couldn't be used with a conventional spring pack.
They seem to be most prevalent with the Cal-Trac crowd.
'63 Dodge 330
11.19 @ 121 mph
Re: Leaf Spring slider Tech [Re: Wirenut] #2755846
03/25/20 02:24 PM
03/25/20 02:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its a roller bearing back where the leaf spring attaches at the rear... as to on the street.. the guys I put them
on for.. none had any issues.. it can make it handle a slight bit better due to less movement(side to side)
wave
Re: Leaf Spring slider Tech [Re: MR_P_BODY] #2755873
03/25/20 03:17 PM
03/25/20 03:17 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
wave
Want to install mine?
Re: Leaf Spring slider Tech [Re: MR_P_BODY] #2755879
03/25/20 03:22 PM
03/25/20 03:22 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
wave
I drive mine on the street a lot, They sell a thick hard nylon block to replace the noisy bearings, custom built 4X4 trucks use sliders a lot !!! it allows the spring to work much better.
Re: Leaf Spring slider Tech [Re: jbc426] #2755882
03/25/20 03:27 PM
03/25/20 03:27 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted by jbc426
How do the sliders effect handling, or are they for drag racing only?
No, we used them years ago when dirt track cars still used leaf springs. It was years before I saw them on anything else.
Re: Leaf Spring slider Tech [Re: RATTRAP] #2755892
03/25/20 03:50 PM
03/25/20 03:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
I quit doing side work after I retired.. they are pretty easy to put on.. if you put them straight on
they will lower the back of the car some(about 1")
wave
Re: Leaf Spring slider Tech [Re: MR_P_BODY] #2756017
03/25/20 08:17 PM
03/25/20 08:17 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
any Video of a car like this in launch?
Any video of what’s going on with the slider at launch?
Re: Leaf Spring slider Tech [Re: Wirenut] #2756026
03/25/20 08:37 PM
03/25/20 08:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Nothing here
wave
Re: Leaf Spring slider Tech [Re: Wirenut] #2756040
03/25/20 09:32 PM
03/25/20 09:32 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Here is a cool video of Jim Guy's Max Wedge 64 Belvedere.
Re: Leaf Spring slider Tech [Re: topbrent] #2756053
03/25/20 11:00 PM
03/25/20 11:00 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Those sliders need to be moved forward.The slider hits the front of the mount at the launch. The bolt/roller should be 3/4 to the back of the slot,not in the middle. Don't ask how I know laugh2
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Leaf Spring slider Tech [Re: hemi-itis] #2756062
03/25/20 11:29 PM
03/25/20 11:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep.. I use to mount them at 3/4 .. I watched that vid like 6 times to see if they hit
wave
Re: Leaf Spring slider Tech [Re: MR_P_BODY] #2756279
03/26/20 08:07 PM
03/26/20 08:07 PM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
wave
would the type of shock or leafs have effect on that 3/4" measurement?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Leaf Spring slider Tech [Re: topbrent] #2756295
03/26/20 09:37 PM
03/26/20 09:37 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Thanks for the video
Re: Leaf Spring slider Tech [Re: Stroker Scamp] #2756301
03/26/20 09:51 PM
03/26/20 09:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
It shouldnt unless the springs are shorter or longer.. the shock shouldnt
wave
Re: Leaf Spring slider Tech [Re: MR_P_BODY] #2756430
03/27/20 10:43 AM
03/27/20 10:43 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
My Dakota, they are not bottoming out.
https://www.youtube.com/watch?v=Vp1edw96lVs
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Leaf Spring slider Tech [Re: WHITEDART] #2756456
03/27/20 12:21 PM
03/27/20 12:21 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Who's sliders did you use?
Re: Leaf Spring slider Tech [Re: justinp61] #2756492
03/27/20 02:08 PM
03/27/20 02:08 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I used these and custom bracket with the angle built it.
https://www.speedwaymotors.com/Speedway-Heavy-Duty-Chrysler-Type-Leaf-Spring-Slider,5817.html
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Leaf Spring slider Tech [Re: Adobedude] #2756512
03/27/20 02:50 PM
03/27/20 02:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
They look close but I've raced against this car plenty. It works real well. Agreed though there is slot not being used at the rear of the travel.
Doug
Page 2 of 3 1 2 3
