Re: Front speaker mounting
[Re: NITROUSN]
#2755741
03/25/20 11:16 AM
03/25/20 11:16 AM
Posts: 3,527 Lansing, MI
70gtx440dana
Lansing, MI
Center speaker wiring is typically pointed toward the LH (driver side). This is also the side of the radio where the speaker wires are attached. Can't remember if the bracket has a specific orientation.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: NITROUSN]
#2755821
03/25/20 01:45 PM
03/25/20 01:45 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Thanks. I sort of figured the wires would be on the left. I just would like to mount it correctly even though no one will see it. Hopefully someone will have a mounting answer. Correct, wires towards the cluster (drivers side)
[Re: Cuda340]
#2755965
03/25/20 05:57 PM
03/25/20 05:57 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Thanks. I sort of figured the wires would be on the left. I just would like to mount it correctly even though no one will see it. Hopefully someone will have a mounting answer. Correct, wires towards the cluster (drivers side) Right. I just need to know which way the offset goes on the speaker mount to dash frame.
[Re: NITROUSN]
#2757518
03/30/20 10:22 AM
03/30/20 10:22 AM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
Not sure if this will help. This is a dash assembly I pulled out of a 4 door parts car that was pretty much unmolested. It looks like the bracket has a front/back offset.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
