4 speed id #2754971
03/23/20 11:48 AM
03/23/20 11:48 AM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
have a 4 speed with dual mount tailshaft,stamped on the pad is UA182132 anyone know what this came out of?
Re: 4 speed id [Re: TB3CUDA] #2754974
03/23/20 11:56 AM
03/23/20 11:56 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Could it be 0A ?
A photo of the pad also showing the date may help.
If it is actually 0A then it would be from a B-body since that is all Lynch Road produced for the '70 model year.
Re: 4 speed id [Re: Alaskan_TA] #2754975
03/23/20 11:59 AM
03/23/20 11:59 AM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
my bad it is OA kinda strange for it to have dual shift pattern on the taillshaft,has a e body pistol grip shifter but mounted on the front mount with b body rods.
Re: 4 speed id [Re: TB3CUDA] #2754976
03/23/20 12:00 PM
03/23/20 12:00 PM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
heres the rest of the numbers pp833 3031 010
Re: 4 speed id [Re: TB3CUDA] #2754995
03/23/20 12:38 PM
03/23/20 12:38 PM
VA
dragon slayer Offline
VA
Mopar did that 70 and up, also truck overdrive had dual mount. Are both machined (threaded)?
Re: 4 speed id [Re: TB3CUDA] #2755037
03/23/20 01:59 PM
03/23/20 01:59 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Maybe someone had it in a 1971 B-body with a bench seat?
Again, a photo would help.
Re: 4 speed id [Re: Alaskan_TA] #2755360
03/24/20 09:53 AM
03/24/20 09:53 AM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
pics,stamped on pad oa182132- pp833 3031 010
Re: 4 speed id [Re: TB3CUDA] #2755433
03/24/20 12:46 PM
03/24/20 12:46 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
that is 23-spline scope correct?
everything looks typical for a '70 B-body except for the E-body "pistol-grip"
the shifter looks aftermarket with the adjustable stops, but does look to have the reverse lever for a 1970 B-body "pistol-grip", is it stamped "7174"?
Re: 4 speed id [Re: 6bblgt] #2755519
03/24/20 04:45 PM
03/24/20 04:45 PM
New York
rarefish Offline
rarefish  Offline
New York
The 3031 stamped on the pad is your assembly date, which would be Nov. 14, 1969
Re: 4 speed id [Re: rarefish] #2755579
03/24/20 08:37 PM
03/24/20 08:37 PM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
yes 23 spline thanks for the info,havent looked at the shifter box but will look for that number
Re: 4 speed id [Re: TB3CUDA] #2755599
03/24/20 09:23 PM
03/24/20 09:23 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ma did use the shifter box with stops in early cars.My 65 has one Hurst Super.Been there for the 50 years Ive owned it and was OE when I bought the car.Better than the cheaper boxes they used later.They also had a bolt on stick.have a 71 pistol grip I modded to bolt to my box.Rocky
Chrysler Firepower
Re: 4 speed id [Re: 6bblgt] #2755705
03/25/20 09:40 AM
03/25/20 09:40 AM
VA
VA
Not a 70B, all levers are longer in 70. Shifter looks like the 71 up B&E.
Re: 4 speed id [Re: dragon slayer] #2755739
03/25/20 11:13 AM
03/25/20 11:13 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
What does the mounting plate look like. What are the numbers on the flat rectangular pieces of metal at the ends of the rods that bolt onto the transmission. Looks like someone might of had some problems and bought some aftermarket shifter or parts to use and tossed some OEM parts.
1971 HEMI E BODY REGISTRY
