Re: WiFi booster
[Re: fastmark]
#2755340
03/24/20 08:47 AM
03/24/20 08:47 AM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
When we were full-time RVers I had an antenna (still have it, AAMOF) that I put on the ladder and connected to a router in the camper. Worked great and the signal I was picking up was about 250 ft. away. I forget what the range was on it. Not the one I have but works the same and says good for 300-400 ft. and several walls. https://www.amazon.com/Crane-Super-USB-Wifi-Antenna/dp/B004UR72IMTim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: WiFi booster
[Re: fastmark]
#2755371
03/24/20 10:28 AM
03/24/20 10:28 AM
Posts: 19,405 north of coder
moparx
be careful about double house hookups. in some jurisdictions, that is considered "theft of services", even with your good intent. it has happened several times around here. it's ok for your cable provider to rip you off, but not the other way around.
Re: WiFi booster
[Re: moparx]
#2755387
03/24/20 11:16 AM
03/24/20 11:16 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I pick up wifi in my shop that is 75 feet from my house - with NO booster. I think you'd be good for 150 feet with a booster. Surely the distance would be in the booster specs !!
Keep in mind that using the internet for TV is very reliant on internet speed as well as what the signal is going through. And I haven't had much luck with Wifi for the tv's. One sits right above the modem and the other one floor directly below. Neither of them worked worth a damn wirelessly. Now both are hardwired to the modem and work like a charm. I've used a variety on android boxes and am now using an Amazon Firestick. This works great for paid services like Netflix and Prime BUT when I'm using a source like Kodi it still has buffering issues.
Re: WiFi booster
[Re: Stanton]
#2755439
03/24/20 01:02 PM
03/24/20 01:02 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
My shop computer is inside of a tight building and 100'+ from the main modem which is inside of another tight building. I am using two APs - access points - one at the modem, one at my computer. All is inside of the buildings. It works pretty well, I expect it would work better with external antennas but haven't done that yet.
Re: WiFi booster
[Re: CMcAllister]
#2755471
03/24/20 02:48 PM
03/24/20 02:48 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
In the OP's use it would be very hard for the cable company to prove theft of service. Radio waves are hard to prove. NOW, if you run an Ethernet cable over the alley and hooked up then yes easy to prove. A Cat5e cable is good for 320 feet. You just put a RJ-45 568B jack on both ends and use the Ethernet connect cables to the routers....
At the moms house you MUST make sure she has the security set high. Then using her SSID and password you just use the amplified antenna to capture her signal. Now at her house you may need a 'Range Extender' that linkes to her SSID and rebrodcasts a second SSID and password. That extender need to be somewhere in the middle and get good receiption from both users. LAG in PING times will not let you 'GAME' but streaming most times it works. But you will get enough delay from when you click your mouse button till the reply gets back to you....
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
Re: WiFi booster
[Re: Dave_J]
#2755593
03/24/20 09:09 PM
03/24/20 09:09 PM
Posts: 6,250 nowhere
Sniper
nowhere
Another thing that helps is to scan what wifi cahnnels are being used and set your router to one that has the least number of users, check int eh evening as that is when most users are online. This is the one I use http://www.wifichannelscanner.com/Just ran a scan. have two other users on that channel so I will change to an unused channel.
Re: WiFi booster
[Re: Dcuda69]
#2755676
03/25/20 06:29 AM
03/25/20 06:29 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
"Cord cutting" is the norm nowadays but you must have great internet. It has put a hurting on worthless cable TV channels as they (All cable channels) get a stipend of your monthly bill. Comcast and Spectrum have taken a hit but they are still doing fine as they have the market corned with their high speed internet. There are some free channels that are worthy to stream as well. Pluto TV and the Roku Channel to name a couple.
Keep old mopars alive.
Re: WiFi booster
[Re: 2boltmain]
#2755880
03/25/20 03:24 PM
03/25/20 03:24 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
"Cord cutting" is the norm nowadays but you must have great internet. This^. I'd be dead in the water without internet. But I haven't had TV - sat or cable - for many years. Those times when I go to a home where the stuff is on. I see nothing I'm missing out on. It's crap. Mindless crap, propaganda and incessant stupid commercials for more crap. Wouldn't have it if it were free. Internet is a necessity. And I don't do a lot of useless fooling around on it.
Re: WiFi booster
[Re: Dcuda69]
#2756008
03/25/20 07:50 PM
03/25/20 07:50 PM
Posts: 6,393 Abilene, Texas
fastmark
Abilene, Texas
How do you get "hosed" by a company that you willing choose to give your money to? Simple..they keep jacking rates and adding silly fees. My bill went up 3 months in a row and the only thing that changed was "misc, fees" even though they couldn't tell me what those fees were. I kept the internet and told them to keep the rest. I stream all my TV now using Firesticks, Prime,Netflix and Hulu+ Live. I get 200 mbps and even at that the live stuff on Hulu buffers at times, not horrible but it happens. I can live with it saving over $800/year compared to cable. I have more stuff to watch than ever...I don't miss cable one bit. Exactly. I pay for BOTH cable bills to the tune of $340 a month now. They keep going up. All the added fees are ridiculous. All I use is internet now. All cable has is commercials anyway.
Re: WiFi booster
[Re: fastmark]
#2756186
03/26/20 01:20 PM
03/26/20 01:20 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Check the range on this baby !!!
Re: WiFi booster
[Re: Stanton]
#2756197
03/26/20 02:31 PM
03/26/20 02:31 PM
Dave_J
Auburn WA
Did not work for my 25 miles from Seattle. It did bring in 7 channels, 2 PBS, 1 Spanish children, 4 QVC type. Wifi boost was OK but not great. Returned it. A review on that baby. https://www.youtube.com/watch?v=dE3sgSnjhKY
